My LG monitor having few problem, 1.few dark shade showing on top left and right corner. 2.though monitor brightness is 100% but not showing properly.
  • 11,800 Answers
Most LG monitors use TN panel. These panels have a very limited angle of viewing so when viewing up close or from a side the image will be degraded. This is how the monitor normally works, there's nothing you can do to make it better.
Posted on Aug 03, 2010
Monitor is set to 100%--still too dull
If the picture is dark, on screen brightness will not overcome this.
Apr 01, 2014 | IBM E74 Monitor
Picture dark
Locate the Fn (Function) key on your keyboard.
It may be on the bottom left side with dark blue letters.
Locate the two "brightness" keys near the top of the keyboard.
These will be in the "F" keys, possibly if F6 and F7.
They should have little sun pictures or something similar to indicate brightness.
Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness.
Tap F7 repeatedly until you reach the desired brightness.
Fn must be held down as you continue to tap.
check vga card
Click the Windows orb logo at the bottom of the desktop to show the start menu.Click the "Control Panel" from the menu to open a window.
Type "troubleshooter" in the search box in the top-right corner of the window.Click the "Troubleshooting" link that appears in the center of the window in the search results.
Click "View All" in the left pane of the window.
Click "Display Quality," and Windows will begin checking the computers video card adapter. Monitor the screen, answer the questions and follow the instructions if a problem and solution are given by Windows.
Feb 20, 2014 | Computers & Internet
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
It looks very dark
The fault could be a faulty inverter board or a faulty CCFD lamp.
The inverter supplies high voltage to the CCFL lamp. The CCFL lamp is a mini fluro lamp and can dim with age.
Check LCD Parts for service, parts and DIY info - click on this link to their WEB site : -
www.lcdparts.net
Oct 06, 2009 | LG Flatron Ez T910BU 19" CRT Monitor
LG Computer Half Light, Half dark?!?!!?
Install the forteManager software that comes with your LG LCD monitor. Go to the Options tab and choose Restore which will set it back to factory settings. For some reason some monitors come this way out of the box and this was the only way I was able to solve the problem with mine.
Sep 18, 2009 | LG Flatron L1919S LCD Monitor
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
LG Flatron E700SH
Hi its not problem it is just setting difference
Try this one
go to menu setting and increase TEMPERATURE to 8300 or between 8300 to 9300
this will help you to solve your problem
thanks and regards
Teknas
Aug 17, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Convergence problem
no u cannot do anything on ur own u need to call an expert,
Apr 04, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
I have have this TV for almost 3 yrs..now have a shaded area on the left side
The dark side of the screen causes of the lamp alignment or prism glass alignment. This is critical you have to consult your LG technician to do this. But if you have any background o repair consult the service manual. Please careful not to touch the prism quarts so that you maintained the clarity of picture and brightness on the screen.
Aug 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
