Question about Haier Mechanical Air Conditioner HWF05XC7
How to stop my haier air conditioner from freezing up?
  • 34 Answers
It could be low of freon....common cause
Posted on Aug 03, 2010
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Posted on Sep 24, 2008
relaga58
  • 158 Answers
SOURCE: air conditioner not working
have you tried turning off and on power from the plug ?
Posted on Aug 17, 2009
  • 10865 Answers
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Posted on Jul 06, 2010
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
SOURCE: Leaking Haier Commercial Cool air conditioner.
there are 3 drain holes in the primary pan right underneath the evaporator that need to be clean with a pipe cleaner or a wire of somekind and there is also a secondary drain behind it that will work only if the unit is 100% level. To access the primary drain pan you have to take all the screws of the back cover 5 on each side and 3 in the center above the electric cord and behind the air filter and only then will you be able to see these very small holes. Use a flashlight to make sure. Have fun!Reply
Posted on Jul 07, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
Posted on Jan 04, 2011
Wont turn on display says stop
Air Conditioner Haier CPRB07XC7 User Manual (36 pages)
Haier cprb07xc7: user guide Size: 2.13 MB
Aug 21, 2013 | Haier CPRB09XC7 Portable Air Conditioner
My window ac unit keeps cycling off, before it gets to the assigned temperature. Help
What may be at issue is evaporator icing. Some units cycle the compressor, others control the refrigerant to keep the evaporator temp just above freezing. If allowed to continue the evaporator would freeze over and air flow would stop....
Check and see if that is the case...
Jul 20, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
I have a Haier ESA406K 10,000 BTU's that just
sounds like you have a small refrigerant leak which would at first result in the evaporator coil freezing over, then eventually not working at all.
Jun 11, 2011 | Haier Heating & Cooling
My haier freezes over the front how do i fix it?
Clean evaporator, and condenser coils.
check for low air volume.
Must be blowing strong.
Air volume is my guess.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 05, 2010 | Haier hwr10xc6 Air Conditioner
Why is my air conditioner freezing up?
The most common reason for an air conditioner to freeze is a clogged evaporator coil. Check and see if the filter is clean If yes then pull the unit our of its case and use the garden hose to clean it out. If it freezes after all of these steps it likely needs a shot of refrigerant.
Jun 27, 2010 | Haier ESA306 Air Conditioner
I have jusdt purchased the air conditioner and it wont stop freezing up and shooting out water and ice
the filter up front is not alowing air through the condenser or the condenser is plugged up if the condenser is plugged up you can take a pressure washer to the condenser up front behind the filter and clean it out.
Jun 19, 2010 | Haier Heating & Cooling
My haier window air unit keeps freezing up I think that its the thermostat becaue it never shuts off how would I repair this?
You either have a dirty coil or filter,your blower isn't running at the proper speed or you are low on refrigerant.
Jun 17, 2010 | Haier HWR05XC7 Wall/Window Air Conditioner
Haier Mechanical Air Conditioner HWF05XC7 Logo
82 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
