Question about Samsung SRS20DTD Side by Side Refrigerator
BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
Plugged in our new upright freezer- Can't figure out what the switch is for inside the freezer. Yellow light comes on when you hit this switch. At first when plugged in you get a green light, a red light and the yellow if you flick the inside switch. Any ideas?
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Posted on Sep 27, 2010
  • leeanneh1970 Sep 29, 2010
    We just bought one too, and wondered the same thing. After some thinking...wondering if it's a defrost button. If the yellow light is on, the freezer is defrosting (you flick the switch to get it started).
    The red light indicated that the freezer wasn't cold enough...after about an hour of having the freezer plugged in, it went off.
    Make sense?
  • ingstine Sep 30, 2010
    I actually talked to someone with a different but similar Brada freezer. Yes the red light is if its not cold enough. The yellow light they said is an extra cool down function? Apparently you can flip the switch for an hour and it cools down faster... then flip it off. I haven't confirmed this but it could be?
  • 3 Answers
I just bought a Brada MF-305. Owner manual didn't say, but there is a switch just over the front door. This switch must be turned on. Also, the temperature switch at the top: rotates clockwise from min to max. But can also go counterclockwise pass the min. Just push in a bit and turn counterclockwise to the Stop mark. Before you plug the freezer: 1. put the switch to ON (I); 2: Puty the temperature selector half way clockwise between min and max. 3: plug the freeze
All 3 lights will light. If you touch the back radiator, it should be warm if the freezer is cooling. But don't tamper with the knob. It may take five minutes before the compressor starts. Once the freezer is cold, the red light will go off. As for the yellow light, it still hasn't come off and freezer temp is -10C. Probably not worth worrying about.
Posted on Mar 10, 2011
  • ah727 Mar 10, 2011
    Correction: if you put the ON-OFF switch to 0, yellow light comes off. This switch must be a Fast Freeze switch
  • Linda Watkins
    Linda Watkins Mar 03, 2013
    IT,S WRITTEN RIGHT THERE UNDER THE YELLOW LIGHT
How do you rverse the door opening?
Posted on Mar 21, 2011
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Frigidaire upright freezer
If your freezer is a frost free, then it has probably stopped in a defrost cycle. The defrost timer is in the back lower left side of the unit, it has a little nub in the center on one side, if you can turn it clockwise and the unit comes on, you will need to replace the timer part #297318010
Oct 21, 2017 | Freezers
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Brand new freezer
FIRST TURN THE TEMP CONTRAL ALL THE WAY OFF.LISTEN FOR A CLICK AND TURN TO HALF WAY SETTING IF IT CLICK IT'S ALLRIGHT, NEVER TO COLDEST,NEXT PLUG A RADIO IN THE PLUG TO MAKE SURE YOU HAVE POWER,DOES YOUR FREEZER HAVE A LIGHT ON FRONT TO TELL IF POWER IS ON?ALSO CHECK BREAKER BOX,THANKS-MIKE
May 19, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
6,274 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
