Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
My internet speeds are up & down what can i do to help determine if its my modem or my providers signal.
    President:
  • 1,768 Answers
1. This may be the ISP ( internet service provider) or you will need to check the drop or line to your house. Sometime moisture, rodents, or the elements have damaged the cable or DSL line to you premise that causes slow speeds and intermittent connectivity.
2. Contact you service provider and ask for a line check. This will require a cable/DSL tech to come to you house to check the line. There will be a charge if nothing is found.
Posted on Aug 03, 2010
How to speed up internet network
The speed of your internet is determined by your service provider and their modem. If possible, connect directly to the modem to check the speed. If you suspect you D-Link router is not allowing you to get full internet speed, first a Hard Reboot of you Router and Modem.
If that did not solve the issue, try a known working LAN 5e cable between your modem and router. After you have established it is not a cable issue, do a factory reset.
I had an issue where my speed to the internet modem was fine, but the router LAN connections only provide a faction of the internet speed. After testing cables, etc I did a factory reset and it restored full connection speed on my router LAN ports.
Feb 27, 2016 | D-Link Computers & Internet
My internet is too slow.I'd like to get it fast
Have to have the company sweep the entire street
& clean up the cable --they will do that for free
Call them & complain,have to be home, so they can sweep
house as well
Next would be your computer
May need to reload Windows every 2 or 3 years
Then if like my cable company-- it still is not enjoyable
to use & is slow
Nov 27, 2014 | Computers & Internet
Internet speed slowed down after install of win 8.1
The type of Internet connection you use in windows 8 is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up.Check with your phone company or Internet provider for more information.Then if you check your speed from http://www.scanmyspeed.com you will definitely see the difference
ScanmySpeed.com
Mar 02, 2014 | Arris Computers & Internet
I wanted to know what is the best wireless router compatible with motorolla SBV5120 cable modem? thank you very much
The Motorola SB5120 SURFboard® is a very popular, solid and reliable cable modem compatible with most cable providers. If your modem is two years or older, upgrading to the SB5120 has been known to show speed improvements up to 3X faster than older DOCSIS 1.0 modems. Set up is simple and fast.
  • Compact design: With its attractive and compact design, this cable modem won't clutter up your work space
  • Easy to maintain: Simplify troubleshooting with the handy font-panel LEDs and built-in HTML-based diagnostics
  • Stand-by switch: Disconnect the signal without unplugging the modem with the top-mounted stand-by switch
  • DOCSIS™ 2.0: Take advantage of DOCSIS 2.0 technology for up to three times greater upstream capabilities than older modems running on DOCSIS 1.1
Linksys BEFCMU10
Quick to set up at a great price, the Linksys BEFCMU10 offers fast connections to your cable broadband provider. Connect it directly to any PC with an available USB or Ethernet port, and you're ready to surf the Internet. With the Linksys Cable Modem, you'll avoid monthly rent charges, and make the most of your high-speed cable Internet connection.
  • Compliant with all industry standards: DOCSIS™ 1.0, 1.1, and 2.0 - compatible with any cable Internet provider
  • Ports: Ethernet, USB & Cable
  • Buttons: Reset
  • LED Indicators: Power, Internet Cable, Internet Activity, Ethernet & USB
  • Easy installation: One phone call to your Internet service provider completes the setup
D-Link DCM-202
D-Link's DCM-202 Cable Modem is powered by TurboDOX™ bandwidth acceleration software increasing your download speeds up to 20 times. The DCM-202 makes your broadband connection more efficient and effective by clearing network congestion, resulting in a boost in download speeds. With the DCM-202, you will get more out of your broadband connection with increased bandwidth and enhanced performance.
  • Always On, Always Connected
  • DOCSIS™ 2.0 Certified
  • Ethernet or USB Connectivity
Netgear WGT624 Super G 108 Mbps Wireless Router Netgear's WGT624 108 Mbps Wireless Firewall Router is 10 times faster than 802.11b routers providing 4x the range of 802.11b devices, and double the range of most other 802.11g products. Your home network is secure with over 10 security and privacy features including a double firewall and wireless encryption. Netgear's Smart Wizard set up software gets you connected in 5 clicks or less!
  • Interoperable with existing 802.11b and 802.11g networks
  • Smart Wizard gets you up and running in fewer than five clicks
  • Lighted power, test, Internet, wireless and LAN status icons
  • Works with most Internet gaming applications that support Universal Plug and Play
Dec 12, 2010 | Computers & Internet
My internet connection is too slow...i use usb modem(pldt weroam plus)how to make it fast?
Some of the tips to increase internet speed on your USB modem are,
* Place your computer at an elevated place, such as upstairs or near a window. Also, select an open space as your work area instead of an enclosed area bounded by walls. Walls block out the signal, which can cause the Internet speed to slow down.* Access the Internet at a hot spot where your network carrier offers the best network signals.* Connect a clip-on antenna to the USB modem. A number of signal booster antennas, which are designed for assisting USB modems in connecting to distant networks, are offered on the market.* Access the Internet during off peak hours
* Contact your Internet service provider and ask them if you can get a higher bandwidth for your USB modem. If so, inquire about the price. If it sounds reasonable, then you might want to consider it.
Check your internet speed from www.scanmyspeed.com after following these steps. you may find a difference.
Oct 22, 2010 | Computers & Internet
Internet speed slows to a crawl making it impossible to access
Unless you have been infected with a virus, it is otherwise impossible to give you a definite answer.
Many problems associated with this, excluding viruses, are due to limitations imposed from your ISP due to excess usage, P2P blocking by your ISP, or other ISP problems.
Hardware causing this is very rare.
I recommend you scan your PC thoroughly before contacting your ISP to discuss the problems.
Jan 17, 2010 | Microsoft Windows XP Professional
I have internet service through Clear (formerly Clearwire), and am troubleshooting a network problem. I have a problem with my internet connection slowing down to where some sites will not load in, and...
What I would suggest have two browser windows open, 1 is to the regular internet and the 2nd is to 192.168.15.1 which is the clear modem, The username is admin and the password is motorola. Once you are in, make the window the size of the icon in the middle of the screen, this will allow you to watch what the modem is really doing when you are accessing the internet in the other window.. If you see an X over the picture of the world and you still have bars on the right then definately contact them and let them know because it shouldnt do that. I know this as I have the same service here in Philly and I am having issues with it, so I always keep a little window open with that picture so I can watch it.
Jan 17, 2010 | Computers & Internet
Extremely slow internet downloading speed.
Download this small application.
http://www.bandwidth-meter.net/bwmeterpro_setup.exe
and check your Upload and download speed.
it should not be your modem or your system problem.But a system whihc is infected by Adware, malware or spyware are usually slow during browsing.Scan you rPC with a Good anti-Virus with lastest updates installed.
Contacting your Internet Service Provider may most hopefully solve your problem.
Jan 04, 2010 | Computers & Internet
Broadband
Sounds it is your modem. I had a similar issue with my old one. I had a westell 6100F and now have a 6100G that helped. My company had to replace about 150 of line about 1000 Ft away from my house. The cable was in a storm drain and it was getting wet and interupting my internat connection.
Oct 17, 2009 | Computers & Internet
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
133 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
