Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
HOW TO USE DAYLIGHT PROJECTOR IN STEP BY STEP
    President:
  • 567 Answers
Hi LCD projectors have revolutionized the audiovisual industry. With a few clicks of the mouse and strokes of the keyboard, whatever you type on your computer appears instantly on a projection screen in real time. If you have never experimented with an LCD projector, however, do not worry. You can learn how to use an LCD projector.
  • Plug the LCD projector in to a power outlet. Completely plug the power cord in to the back of the LCD projector.
  • Step 2Use a VGA cable (usually a 15-pin male to male) to connect your computer to the LCD projector. Insert one end of the cable into the VGA connector (sometimes this connector is blue) in the back of your computer and do the same in the back of your LCD projector. If the LCD projector has more than one VGA connector, choose the one that says something like "line in" or "in from computer."
  • Step 3Power on your laptop. Turn on the LCD projector. It may take a couple of minutes to warm up. Open the computer file or document you wish to display. When you are ready to project your image, press "Function" (Fn) plus "F8." This combination of keys sends your computer's display to the LCD projector.
  • Posted on Aug 03, 2010
    • Hilton Bristol Aug 03, 2010
    • Use sound to enhance your presentation. Often LCD projectors have built-in speakers. If this is the case, you may need to run an RGB cable from the LCD projector to the back of your computer. If you wish to use external speakers instead of those that are part of the LCD projector (the built-in speakers are generally of poor quality), plug the speakers directly into the headphone jack of your laptop.
    • Step 5Turn off your LCD projector properly. Usually you must press the "off" button once, and a dialog box pops up asking if you are sure you want to turn it off. Press the "off" button again, and the machine powers down. Leave the machine plugged in until the cooling fan stops. Be careful when disconnecting VGA cables from the back of the LCD projector and laptop, as the pins at the end of the cable are delicate.
    • Step 6Know some other features of your LCD projector. Most have a focus knob to make the picture clearer. If your image appears distorted (wider on one side than the other or small at the top, big at the bottom) you must adjust the keystone setting, which helps to project a rectangular image. You can fix keystone distortion manually by moving the LCD projector to position it near the center of the screen at which it is aiming.
    How to set time
    Plug in the unit.
    First, the month and date appear, then the
    year, and then the current Eastern Standard/
    Daylight Time appears in the display.
    Press
    TIME ZONE
    Area number "2" appears in the display.
    If you live in the Eastern Time zone, you do
    not need to adjust the area setting.
    Area number
    Time zone
    Atlantic Standard/
    Daylight Time
    (default)
    Eastern Standard/
    Daylight Time
    Central Standard/
    Daylight Time
    Mountain Standard/
    Daylight Time
    5
    Pacific Standard/Daylight
    Time
    6
    Yukon Standard/Daylight
    Time
    7
    Hawaiian Standard/
    Daylight Time
    Press
    TIME ZONE
    repeatedly until the
    desired number appears.
    The display returns to the clock about 4
    seconds after the operation is complete.
    Note
    During the shipment and your first use, a clock
    error may occur. In this case, refer to "Setting the
    clock and date" to set the correct time.
    When daylight saving time
    (summer time) begins
    This unit employs Automatic Daylight Saving
    Time/Summer Time adjustment. The DST
    indicator appears in the display at the beginning
    of the daylight saving time (summer time), and
    disappears at the end of it.
    Daylight saving time begins at: 2:00 AM on the
    second Sunday of March.
    Standard time begins at: 2:00 AM on the first
    Sunday of November.
    To cancel the automatic DST/summer
    time adjustment and to set DST display
    manually
    The automatic DST/summer time adjustment can
    be cancelled.
    Press and hold
    DST
    for at least 3 seconds while
    the clock is displayed.
    A beep sounds, and "Aut
    OFF" appears in the
    display to show that the automatic DST/summer
    time adjustment is cancelled. The display returns
    to the clock.
    Notes
    Daylight Saving Time depends on the law in
    each country/region, and your area may not use
    it. In such a case, cancel the automatic DST/
    summer time adjustment before using the set
    and set the time manually as necessary.
    To activate the automatic DST/summer time
    adjustment again, press and hold
    DST
    for at
    least 3 seconds. A beep sounds, and "Aut
    On" appears in the display to show that the
    automatic DST/summer time adjustment is
    activated. The display returns to the clock.
    To change the display to the daylight saving
    time (summer time) manually, see "To change
    the display to the daylight saving time (summer
    time) indication."
    Setting the clock and
    date
    To change the setting manually, follow the
    procedure from step
    Press
    CLOCK
    for at least 2 seconds.
    You will hear a beep and the year will start to
    flash in the display.
    Press
    or
    until the correct year
    Press
    CLOCK
    Repeat steps
    and
    to set the month,
    day and time.
    After setting the time, two short beeps sound
    and the clock starts from 0 seconds.
    Pressing and holding
    or
    changes the year,
    month or day rapidly.
    When setting the current time, time changes
    rapidly by 1 minute-increments up to 10
    minutes, and then by 10 minute-increments.
    While setting the clock, you must perform each
    step within 65 seconds, or the clock setting
    mode will be cancelled.
    To display the year and date
    Press
    SNOOZE/DATE/SLEEP OFF
    once for the
    date, and within about 3 seconds press it again for
    the year.
    The display shows the date or year for about 3
    seconds and then changes back to the current
    time.
    If you connect the AC plug to an AC outlet while
    this unit is powered from the backup power
    source, the current date and time appears in the
    following order (the same as when the unit is
    powered on after a power interruption).
    "month and date" (about 1 second)
    "year"
    (about 1 second)
    "current time"
    saving time (summer time) indication
    Change the daylight saving time (summer time)
    adjustment setting according to the following
    procedures if you have cancelled the automatic
    DST/summer time adjustment.
    Press
    DST
    The DST indicator appears in the display and the
    time indication changes to the daylight saving
    time (summer time).
    To deactivate the daylight saving time (summer
    time) adjustment, press
    DST
    again.
    May 24, 2015 | Sony SY-ICF-C414 Clock Radio
    I have the s55 model flood light, i want to know if I can replaced with daylight bulb
    the projectors use Ultra High Pressure lamps
    there are different from daylight bulbs
    the lamp for S55 ,price :USD120
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Lampdeng Limited
    Jerry
    Apr 22, 2014 | 3M 78-6969-9790-3 OEM Compatible...
    Lamp not firing but sound works
    If all other parts of the projector seem to be working, but no light come from your projector. It may be time to replace the bulb in your machine. There may be other issues with your projector but more often than not, it is time to replace the bulb.
    Here's a helpful guide : http://www.ebay.com/gds/A-Step-by-Step-Guide-to-Replacing-Projector-Lamps-/10000000177628964/g.html
    Mar 12, 2014 | ViewSonic Pro8200 Projector
    Disassemble HP MP2200 Digital Projector
    step by step carefully
    We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
    any questions, feel free to contact me
    have a nice day!
    Jerry,Lampdeng Limited
    Jan 29, 2014 | Office Equipment & Supplies
    Lost manual. how to change remote for time. daylight same
    Step 1: Determine the make and model of your phone.
    Step 2: Repost your question, being sure to include the information from Step 1.
    Mar 13, 2011 | Lands Phones
    Have a panasonic dlp 3yrs old, picture is very dark and hard to see in daylight. Ajusting picture in menue doesn't help. Have noticed a slow deterioration of pcture clarity.
    It is likely to be a combination of things. 1) The lamp is getting weak and should be replaced. 2) The optical pathway needs to be cleaned.
    Cleaning the pathway should be done by a professional as any slight movement will cause the projector to become misaligned. Depending upon the environment where this is used, this time period is within the norms for both lamp life and cleaning.
    Dan
    Feb 13, 2011 | Panasonic PT-D5600U DLP Projector
    After switching on the projector and laptop, the I picture doesn't appear. What can I do?
    Hi please recheck the connections for the projector and laptop,these are the steps:Connect one end of the video cable to the projector unit.
  • Step 2. Connect the 15 pin connector of the cable to the PC.
  • Step 3. Turn on projector
  • Step 4. Turn on PC
  • Aug 09, 2010 | Panasonic Office Equipment & Supplies
    I am trying to set the companies time clock for daylight saving time. Thank you Betty
    send it into Gateway Time Systems in Pittsburgh...they will replace theribbon, clean and lube it, and make sure the program is up to date foryou. they did a wonderfull job on my company's time clock and theybarely charged anything. i found them @ www.shop.gatewaytime.com  goodluck :), Adam
    Nov 02, 2009 | Lathem Time Lathem VIS6002 Ribbon...
    How to reset the lamp timer on a Marantz VP8600 Projector
    To reset the lamp timer for the Marant VP8600 you will need your remote.
    Step 1: Make sure the PJ is powered on
    Step 2: Press the leftt arrow key, then right arrow key, then the Freeze button
    Step 3: Press enter to reset
    Sep 26, 2008 | Marantz VP8600 DLP Projector
    BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
    185 people viewed this question
    Top BenQ Office Equipment & Supplies Experts
    jasbo
    jasbo
    Tom Chichester
    Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
