Question about Abit IS7 Motherboard
Hi there, not sure if my motherboard is dead or the power switch is broken. I put power to the motherboard and a green lights up on the board. Press the switch and it will not work. It was working yesterday, any ideas???
    Brigadier General:
  • 3,513 Answers
Hi
Most probably you have a blown motherboard and if that is so, you need to replace your motherboard.
Please check the bellow link and go through the discussions thoroughly to have an idea regarding your problem…
http://www.techspot.com/vb/topic112181.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 03, 2010
U778K
The first thing I would do is to make sure your power supply is good. I have found that sometimes they will make some of the lights come on, but they may have 12V and not 5V or whatever. I bought a small thing you plug the power supplies into, and then the lights light up to show you if the power supply is supplying what it should. Once you are sure the power supply is good, (don't assume) if they still don't work, I would visually check the boards. I have found many times the small capacitors go bad. After replacing them, the boards worked fine. Usually they will have the top cracked open or bubbled up. If you are up on electronics, as I guess you are if you know how to read a schematic, soldering in new ones is a simple matter. I also remove the CPU, clean the bottom surface off, and put a small amount of CPU grease on and reinstall the CPU. Be sure to check all the pins, as they are pretty small and easy to bend one over.
Jan 01, 2018 | Intel Motherboard
Power supply or motherboard problem?
Hi talissap,
The blinking light is telling you something about the PSU. First check any AC mains voltage select switches for proper setting. US should be 115. Second if you have a multimeter, you could test the PSU for voltage. Disconnect all power to all components. remove all components from the board including cpu, memory . Leave the PSU only plugged into the board. Press power. If the fan turns on then it's not the power supply. The brand power supply isn't the best, I've seen where you need to wait for 5-20 minutes for the blinking to stop, at which time it will fire up. Now, if it doesn't power up, then it's most likely the PSU.
Good Luck,
Mark
Dec 08, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
Dell 5100 won't come up after memory swap
Did you make sure that the power supply was off and or discontected from power source before opening the case?
It is possible that you have fried something by having a static discharge either from you hands or the vacume cleaner hose. Have you checked the correct installation of the memory make sure you are putting the original memory in dimm1 and dimm2.
Also check that the power button is still connected to the mother board just follow the wire from the back of the button just to be sure. Also check that the power switch on th power supply is on.
Link is to manual
http://support.dell.com/support/edocs/systems/dim5100/en/om/T8144bk2.pdf
Jan 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Red lights on board
i never had green lights on my motherboard, they have always been red and it runs fine. the mother board was made with red led lights. if its not working right, it's probably the switches on the mother board, normally make the first switch on, and the other 3 off.
Aug 12, 2008 | DFI LanParty KT400A Motherboard
Pc is dead
is the power switch wire hooked up in the right place
Jun 03, 2008 | Intel Desktop Board D850GB Motherboard
Asus k8v-mx motherboard
BIOS of your motherboard is crashed. M/B needs to be replaced
Jan 12, 2008 | ASUS K8V-MX Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
Abit IS7 Motherboard Logo
18 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
