Question about Hampton Bay 30 In. High Velocity Pedestal Fan in Chrome Finish
What size capacitor should i use on a 30" hp-30 shop air circulation. The motor is 120v ac 60hz 3.0A and the capacitor that is on the motor is bubbled and not working is a 250 v ac. Should it be a 250 or 120v
I need to know the specs for whirlpool rs630pxk
Do you need the size of the RS630PXK range? The range is 30" wide, 31 7/8" high and 22 3/4" deep. The installation opening needs to be larger to allow for air circulation around the range. It needs 120V AC power. The specifications for the size and the installation space size is given in the installation guide. Whirlpool has the guide on their product support page. The direct link to the installation guide is http://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%20311433.pdf . All of the documentation can be found by searching on the model number starting here: http://www.whirlpool.com/manuals/ .
I hope this helps.
Sep 30, 2015 | Whirlpool Stove / Oven / Range Cooktop -...
Label on FAN motor model E226911 SJD-B1 120V 60HZ 0.237A, INS. CL A, 2780RPM THERM PROTECTED L, CAPACITOR 2.0MFD SAGITTA IND.CORP.DECEMBER-2006. how do I fix or find one
go to an electrical motor shop and get the capacitor as most motor problems (if they are not burnt out Check by the smell) are related to the capacitor.
Dec 18, 2014 | Cars & Trucks
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Timer gets off by hours
I have circulation system on my water heater.
First system gave out.
When taken apart, it was clogged with sediment and couldn't be cleaned.
Put sediment filter on line, and second circulation system works fine, and timer works fine too.
I haven't had timer problem, but have investigated timer motors running fast and slow.
My friend who re-winds big pump motors says homeowner timer motors are engineered for 60Hz.
As long as electric power is 60Hz (60 cycle AC), then motor will keep exact time.
Since your household current is 60Hz and other electro-mechanical timers run correctly, then it's likely timer motor has a flaw or has gone bad.
Grundfos water heater re-circulation pump and timer are sealed unit.
Grundfos manuals do not show parts list or repair steps:
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
It's aggravating when expensive household timers like Malibu power packs and Grundfos pumps are not made to be repaired.
Nov 24, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
How much power (kw/hr) does a D55152 use at full capacity?
Below you will find the power requirements for your compressor. I would recommend not to use an extension cord due to possible damage to capacitor. My dewalt a/c, with same motor, is actually using 17.5 amps right before shut off. Good Luck!
  • Drive: Direct
  • Horsepower: 2.7 MAX HP
  • Tank Size: 4 gal
  • Power Supply: 120V AC, 15 amps,
    >60 Hz, 2 pol induction motor
  • CFM @100 PSI: 3.8 CFM
  • Pump Speed: 3400 rpm
  • Tool Length: 18"
  • Tool Width: 18"
  • Tool Height: 16"
  • Tool Weight: 65 lbs
  • Oct 15, 2009 | Dewalt Heavy - Duty 1.1 Hp Continuous 4...
    I need motor brushes for campbell hausfeld WL611105AJ air comp.
    If you can find a match to the brushes that came out of the motor they will work. When I say match, I mean the size. Height, width and depth, length only needs to be close to allow for wear over time. The longer the brush the more wear you will get. If you can't find the exact size then you can always file a larger brush to fit. I just had to do that for a small motor in my shop-vac, works great. Also another consideration is how the line coming off the back of the brush connects to the Stator. If you can't match the connector soldering it is fine or crimp the appropriate connector to it. Beyond those two elements brushes are pretty much the same.
    Your biggest problem is finding an assortment of brushes. Some hardware stores will carry some, (check the bins with all the small nut, bolts and other connectors), also automotive parts stores carry them, (for alternators),. Your best bet would be an electric motor repair shop.
    Good luck
    Apr 15, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
    (I need a new electric motor for my air compressor. Where do I find one?
    I think I can help you guys needing a replacement CC-5440M12 120V/60Hz Ronning Motor. I have been cleaning out my shop and I have four (4) of these used electric motors. All work fine. They still have the plastic fan blade on one end and the metal gear on the other. I actually have electric cords wired up on each of them that I used to make sure they worked.
    Thought I would pass this information on to you. Thanks and have a great day.
    Oct 07, 2008 | Dewalt 2 Hp 4 GAL Air Compressor
    Hampton Bay 30 In. High Velocity Pedestal Fan in Chrome Finish Logo
    48 people viewed this question
    Top Hampton Bay Dryers Experts
    Steve
    Craig Butler
    Craig Butler
    Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
