Question about Nintendo Wii Console
When i put a disc ...the screen goes black and then it says error reading disc please press the eject button and turn the console off. what do i do?
  • 21 Answers
You get this error when
Laser times out
or disc is not spinning
1 Check disc make sure its clean etc
2 put ear to wii and listen for disc spinning (if not laser or spinner can be bad)
3 if you hear spinning and it stops in a few seconds laser is probably bad or dirty ( if you can open system and clean laser if that doesn't help replace laser) If you cant seek repair tech help nintendo or otherwise
Posted on Aug 03, 2010
  • 3,866 Answers
The cause here is the Drive itself is ether dirty or showing signes of intermittency now the folks at www.videogamerepair.com can take this into consideration and have it repaired for you if its under warranty or not give them a try. Otherwise you might need to have nontendo get involved.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
The disc will not eject and the wii says to insert a disc
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform: http://www.nintendo.com/consumer/webform...
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
It is possible that you inserted the disc incorrectly. That would account for the error message "Unable to read the disc" or "Disc could not be read." But it should've ejected on its own.
Before calling Nintendo Service you can also see if their Support site has any solutions. Try the link provided in the source.
Good luck.
Dec 29, 2010 | Nintendo Wii Console
After ejecting a disc and putting in another the tv screen displayed an error occurred and we cannot get the power button to shut off to reset it
Do you have any details on what the error was? If it was a 001 read error, or something related, where you often get a green or blue screen, you simply need to FIRST eject the disc by pressing the eject button, then hold the power button down for about 5 seconds and your Wii will shut down.
Jan 31, 2010 | Nintendo Wii Console
Eject disc and turn off console
unfortanatly your right sent that to nintendo it has to be a factory malfunction
Nov 09, 2009 | Nintendo Wii Console
My Wii is no longer reading a disk. I put it in and I get a grinding sound soon after it goes to a black screen that says "an error has occurred. press the eject button and remove the disk and turn the Wii...
I would definatly contact Nintendo customer support. It sounds like your Disc drive on the Wii is going bad. They will either fix or replace your wii, if it is still under warranty then they will do so at no cost to you.
Jun 22, 2009 | Nintendo Wii Console
Wii cant read the disc
try putting the disks in a adiifernt position untill the wii eads it well
Aug 27, 2008 | Nintendo Wii Console
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Nintendo Wii Console Logo
252 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
