Question about Philips Universal PH301S Remote Control
My remote wont change the channels on my tv - Philips Universal PH301S Remote Control
  • 10,865 Answers
The most common cause is weak batteries. Change the batteries and it should work for you. J.
Posted on Aug 03, 2010
Toshiba smart tv stuck on one channel tried new remote wont change channel went back to old remote still the same
Did you try changing the source? It might be getting the channel from a source other than the TV.
Sep 09, 2016 | Toshiba Televison & Video
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Dish network remote turns tv on but wont change channels
1) clean the contacts batteries.
2) change by new batteries
3) resolder wires connectors batteries
4) Open the remote control, and clean the keypads very well with special spray contact R. Shack
5) Otherwise you must go to the repair shop TV, FOR Fix it
GOd bless you
Jun 18, 2012 | DISH Network Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Dish remote wont change channels
make shure it is turned on the sat setting
Oct 05, 2009 | DISH Network IR Remote Control
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
TV is stuck on video 1?
You probably have a replacement remote. It will need to be reprogramed to your tv. You should have instructions that you got with the remot. Otherwise call your TV repair man and he can probably "walk" you through it over the phone.
Jan 12, 2009 | Sanyo DS32224 TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
Televison & Video Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
