Question about Garden
EBay item (US) 280515865217 is an Ozone Generator that claims to put out 16,000 mg/h. Is this actually possible without an oxygen feed? It doesn't say it has an oxygen feed and the guy for some reason won't answer my questions!
  • usedonlytosi Aug 03, 2010
    There seems to be guys who are happy to talk but they are asleep at the moment (timezone difference) with very similar ozone levels. Your answer though is very handy as it gives me something to ask these people about! I accept your solution.
  • 10,865 Answers
The fact that the guy is not getting back to you raises red flags. That is a huge ozone generator. In order to produce 16,000 mg/h of ozone, you would need to utilize at least a 16,000KV transformer (cost over $500, not likely). Go to this link for more http://4o3.us/
J.
Posted on Aug 03, 2010
Microwave burn smell how to remove
put an ozone generator inside for 5-10min. Unplug the microwave, then run the ozone generator for 5-10min. IF that does not work you may need to start replacing plastic bits inside.
Mar 02, 2018 | Microwave Ovens
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Nov 18, 2013 | Ecoquest Living Air Classic Air Purifier
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
I just received an item and it is damaged!
Do this:
Contact the seller. -As soon as possible you should contact your seller to advise that the item has arrived damaged. Check also if it comes with insurance.
Also, send a photograph of the damage - this can be as an attachment to your email. The seller may require the item to be returned to them and, again, you should comply with this but make sure you send the item by trackable means in case you later need to make a paypal claim.
Once the seller has decided to issue a refund this should be completed within a reasonable time. If the refund is not forthcoming you may open a paypal claim to obtain a refund. The claim is called 'Significantly Not As Described' SNAD) and will entitle you to a full refund less return postage costs. You will have to return the item by trackable means and enter the tracking number online.
If the seller does not reply. -File a dispute and escalate it to ebay. Ebay would tell you to send the item back and where to send it. There is no reason to communicate with the seller after the case has been escalated. Return the item with Delivery Confirmation. Once the item shows as delivered back to the seller, you will receive your refund.
Hope this helps.
Sep 19, 2011 | eBay Auctions
My pinnacle dazzle recorder doesn't have a serial
I would file a claim with Ebay to get the money back in return for the Dazzle and order one from an accredited dealer via this link. http://pages.ebay.com/help/buy/business-protection-claim.html
Jul 18, 2011 | Video Game Consoles & Games
I just recieved a model # 10 spa What and when do I use the blower button for and do I need to use the ozone tube located in the front compartment?
the blower when turned on blows air into the spa. you can use it whenever you want to. Just push the button that turns it on. the ozone tube is there for the ozone generator to attach to. if you do not have an ozone generator then you can just leave it alone. It will not affect how your spa works.
Dec 20, 2010 | Plumbing
Received items purchased through ebay broken, how do I proceed?
Hi
Notify the seller about the broken items. Between you and the seller you'll need to determine if the items were broken by the shipper. If so, the seller will file a claim for the broken items. It's up to the seller whether he refunds you prior to the claim being approved. I usually refund as soon as possible. If the seller is unresponsive and/or he did not purchase shipping insurance then you'll nee to file a claim with eBay's New Buyer Assurance. Good luck
Aug 23, 2010 | eBay Auctions
Is this purifier hepa or ozone?
Strictly speaking it is both and neither! It incorporates a high voltage source (18kV) which has the potential to create ozone, though the manufacturer does not claim that ozone is the means by which micoorganisms are defeated. It also incorporates an 85% efficient HEPA filter, but teams it with EMF technology (their own patented technology using the 18kV energy field) to increase the HEPA efficiency to 99.99% (their claim).
Oct 13, 2009 | Healthway EMF 20600-2 Air Purifier
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
Ionic pro turbo
Yes.
The Consumer Products Safety Commission is going to be making a decision on all ionizers. It's possible by the end of the year that no one will be selling them anymore.
This industry should have been regualated years ago even after the EPAs own reports on their own website.
Aug 15, 2008 | Ionic Pro TURBO Air Purifier
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
