Question about Whirlpool Duet GHW9150P Front Load Washer
THE CODE SAYS F07 AND SHUTS DOWN. SOMTIMES I CAN RESTART IT AND SOMETIMES I HAVE TO WAIT UNTIL THE NEXT DAY
  • 171 Answers
F07 is the code for a motor problem.  It could be the MCU ( motor control unit) the cable from the MCU to the motor or the motor itself.  odds are it's the MCU but you might want to have a tech out instead of buying either of the expensive parts first.
Posted on Aug 03, 2010
My PC starts-up said my name welcome and stays on that scree with the spin next to welcome and that's it.
Sometimes updates running in the background act that way. You can wait it out (could be 1/2 hour or more depending on how many updates) or you can try holding "ctrl", "alt" and tap "del" key and see if "task manager" opens up. If it does, it should show what processes and applications are running. That may give you a clue. Finally, you could just hold the power button down a few seconds until it shuts down. Upon restart, you may have to select an option such as "start normally". If you continue to have problems after the restart you may need to go into "system restore" mode (type "system restore" (w/out quotes) in search box of Start menu, follow the prompts and choose the restore point just before the last system change.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brad_a1804065c704c462
Oct 18, 2016 | Gateway SX2110G-UW318 Small Form Factor...
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
'04 L300-3 Stalls randomly and won't start until I wait about 5 min. Then starts normal
try replacing fuel filter , and next time you go to start it turn key on let it sit for count to 50 then start see what happens
Dec 14, 2012 | 2003 Saturn L-Series
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My su g90 shuts off when i turn it up loud what do
Amplifiers get hot. The more you crank the volume up (or use extended for extended periods), the more current is required. When it gets hot, there is a fan motor (on the back), that should turn on. I believe your fan motor (brush) is worn out and therefore non-functional. Under this condition when the system overheats, it automatically changes mode to protect circuits.
Also note: if it works when you initially turn it on (cold) for a few minutes it should work fine...until it starts getting hot inside the case.
Oct 20, 2009 | Technics Audio Players & Recorders
Jeep liberty will shut off and gives a no buss indication light on dash. sometimes restarts and sometimes you have to wait 10 or 15 minute to restart
a bad crank sensor shuts off while going down road. then restarts after 10 minutes, but only until it happens again.
Oct 13, 2009 | 2005 Jeep Liberty
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Whirlpool Duet GHW9150P Front Load Washer Logo
321 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
