WHERE IS PRESSURE SWITCH LOCATED ON FRIDGAIRE FRONTLOADER ATF7000EGO
  • 171 Answers
They usually located in one of the rear corners near the top either right or left.  has a hose similar to an aquarium air filter hose and a wired plug running to it.
Posted on Aug 03, 2010
Where is oil sending unit located?
You're vehicle has two sensors for the oil,an oil pressure sensor switch & oil pressure sensor.If oil pressure gets below 6psi,the oil pressure sensor switch will turn a dash light on to let you know the pressure is at a dangerously low amount.So if you've got a dash light on,the pressure sensor switch needs to be replaced.Its located to the right of the oil filter housing,on a 2.0 liter.Its located to the left of the oil filter housing,on the 3.0 liter.
If your oil pressure gauge is reading inaccurately,you need to replace the oil pressure sensor instead.Its located near the ac compressor.
Oct 15, 2015 | 2003 Ford Escape
Can I bypass safty switch on stackable fridgaire washer/dryer. After it broke and fell off I when I put it on spin cycle water went on floor.
yes u can but remember if u have children its a safety issue. the switch is not that expensive but u can do it see pics
May 17, 2014 | Frigidaire Washing Machines
I have Frigidaire Affinity ATF7000EGO washer. i just replaced the door striker but now everytime it goes to start cycle starts buzzing and reads DR....
Double check that the mechanism is fitted correctly and all wires are attached as off the top of my head that is the error code for the door not sealed properly. Hope this helps.
Nov 17, 2013 | Washing Machines
I have a Whirlpool Duet ht frontloader washer..I'm getting a F20 code...water pressure is good, cleaned out filter, took hoses off and made sure they were clear..any suggestions?? Please help!! Thank you!
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore frontloader washer HE2Plus that says error code
Jan 29, 2010 | Kenmore HE2 Plus Front Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Fridgaire washer is leaking water about 1/2 gallon of water
If you take off the front panel in the VERY back you will see a hose, that hose has seemed to have come disconnected, there is a valve back there that is just slips onto. This will stop your water leak
Feb 08, 2009 | Frigidaire FWS833A Top Load Washer
Frigidaire dryer overheating
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
