Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
The pour spout is all wrong, too small and doesnt pour good. coffee every morning goes all over my counter, no matter how slow you go.. its a pain...I need something with a larger pour spout,not the same kind.................ive waited for over two months for this, and then i see its the same kind, Not Happy
Pour veeeerrrrrry slow...your wrist will hate you, but at least you wont have to clean up spilled coffee
Posted on Aug 08, 2008
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My jura en9 pour spout clogged. How do I disassemble to clean out blockage? It is pour very slow and coffee is leaking out the sides of the spout.
Hi Eric
Can you get a pipe cleaner up the spout and clean?
Otherwise.... Take some photos and start unclipping & unscrewing
Thats how I replaced the Element in mine.
Check YouTube
Nov 08, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Carafe dribbles coffee no matter what you do. Pour fast, pour slow, dry the outside etc. Can't believe they can't make a pour spout that doesn't dribble. Any suggestions?
I often ask why we can put a man on the moon, but not make a coffee maker that doesn't dribble when I pour. I have the same trouble, and what I have found works for me is to be very careful that I am pouring with the spout dead center, and pouring fairly slowly. A little off to the side of the spout, and I'm cleaning the floor. But if I pour so the flow is right through the center, it works for me.
Good luck. And if you design the perfect carafe before I do, let me know. I'll buy one!
Dec 04, 2010 | Cuisinart DCC-450 Coffee Maker
The coffee spout is pouring into the coffee pod collector
I have the sameproblem, I suspect something is blocked but I don't know how to remove the spout????????? Please helP!!!!!
Feb 08, 2010 | Nespresso C100B Essenza Single-Serve...
HAMILTON BEACH BREWSTATION LEAKS FROM SPOUTS
I had the same problem with this same machine. On this model there is a spring-loaded piece of plastic that operates the pouring of the coffee. After a few months of regular use, there is a design flaw in this piece that wears out prematurely, causing the pour to slow down. This is why the stream runs towards the machine and not in your cup.
Eventually the plastic piece will break at the weak point and will stop pouring altogether. To make matters worse, HB uses a weird screw that you cannot turn unless you have the right bit, and, once you do finally get to the piece, there is no where to order a replacement.
Summary: Hamilton Beach built an intentional flaw that is difficult/impossible to repair so you will need to purchase another machine in under a year.
Jan 24, 2010 | Hamilton Beach BrewStation 47224 Coffee...
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
Coffee on the Countertop!
This is how my husband pours: he holds the lid open with the thumb lever and pours. It seems to work better if you pour slow. (I am always in too much of a hurry:)
Jan 30, 2007 | Mr. Coffee TFTX85 Coffee Maker
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
103 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
