Question about VISION GUARD VISION GUARD 8000 SECURITY & REMOTE ENGINE STARTER SYSTEM WITH
Daewoo matiz wont start security led flashing dont have a key with a chip
My alarm went off on my Daewoo matiz se plus won't start now any ideas
Lock it up. open it with the FOB or the key at the drivers door. This should reset the security. If not, have the codes read to see what has died. Could be a sensor or a bad wire. Takes a scanner to get security codes. not a code reader.
Aug 07, 2016 | Daewoo Cars & Trucks
Why daewoo matiz 800cc cranks but wil not start
First things first...check for fault codes..If it was your immobilizer you would have a light on to tell you -(flashing as you turn the key to crank the engine )... and you would have no spark..at the plugs at all.
If your engine has compression, fuel and a spark it will run...
You need to check for fuel and spark as your starting point for trouble shooting your cranks no start problem.
Jul 21, 2016 | Daewoo Cars & Trucks
How to reprogram daewoo matiz key 2000
this normally needs to be with the vehicle as the immobiliser is part of the programming process. Consult the service dealer department for advice
Jul 30, 2014 | 1999 Daewoo Matiz
Daewoo matiz 2001 turn ignition key on ( position2 ) wait 5seconds diagnostics pass and red flashing immobiliser led turns off (1) try to start car by turning key to position3 but starter does not...
Hey David. Your problem is most likely the cables going to the starter. Corrossion (greenish white powder) will travel up the wires and cause alot of resistance. this resistance cuts down the voltage and amperage going to the starter, thus not letting it turn over. This is where I would start to look and replace if necessary. Also at the battery it corrodes as well. use a wire brush to clean here.
Jul 19, 2011 | Daewoo Lanos Cars & Trucks
Can i get a spare key cut for my Daewoo Matiz?
you mught go to dealer and avoid run arounds.....
Dec 23, 2009 | 2001 Daewoo Lanos
Daewoo matiz car is turning but not sparking to
think this could be factory immobiliser ,try spare key if still no joy dealer only
Aug 12, 2009 | 2001 Daewoo Lanos
My daewoo matiz is playing up when i first start it it runs fine after it warms up it starts to have flat spots and missing to the point where it stalls and then it wont start again untill it cools down...
hi
the problem is with the engine cooling system due to the lack of cooling of engine it is over heated so better to check the coolent pipes...
Jul 11, 2009 | 2000 Daewoo Lanos
Power steering for Daewoo Matiz
i have a Daewoo Matiz 2000. It doesn't have Power Steering although other models of Matiz came with Power steering. I want to know if a Power steering can be installed on my Matiz. If so, whom can I contact.
sreejith
Jan 22, 2009 | 2002 Daewoo Lanos
Daewoo matiz 1999 immobiliser code fault car will not start
Daewoo Matiz 2002 (UK version,immobiliser problem,no spark and i changed everything like coil...)
Oct 19, 2008 | Vehicle Parts & Accessories
VISION GUARD VISION GUARD 8000 SECURITY & REMOTE ENGINE STARTER SYSTEM WITH Logo
365 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
