New fan motor, remote control appears to be OK. Unit refuses to start, even when fan started manually separate from unit. No lights appear on PCB.
  • therich12 Aug 03, 2010
    Vulcan Ducted Heating (Automatic)Model 80 ECO . New fan and motor installed (Replacement 'slide out-slide in). Use remote, nothing happens. Motor isolated,works OK. No LEDs light up on Circuit board. It's winter, I'm cold. Previous "expert" gave info for air-conditioning. Vulcan now comes under Rheem, who no longer service this model.Justin Rich therich12@hotmail.com
  • 4,889 Answers
Failed control board seems to be the most likely cause. The one that has the thermostat and stuff.
Posted on Aug 04, 2010
  • therich12 Aug 04, 2010
    My thoughts exactly .. now I can convince the landlord! Thank you for your help. Cheers,Justin Rich
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links to diagnose what is wrong with your Air conditioner…
Please go through the article bellow to have an in-depth knowledge to your problem…
http://www.longviewweb.com/fanon.htm
http://www.hvac-for-beginners.com/air-conditioner-troubleshooting.html
http://www.inspectapedia.com/aircond/aircond15e.htm
http://www.green-energy-efficient-homes.com/home-air-conditioning-problems.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 03, 2010
    On the questionnaire, gave the make, model of my ducted heating system. I have received suggestions for air-conditioning, i.e. cold air equipment. It's winter, I don't like being cold. Vulcan ECO 80 ducted heating. Wrong advice ... do I get a refund!? Anyway, thank you for your speedy reply. Justin Rich.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
E3 code appears and unit wont operate Domain Air CSR5300
E-3 Indoor unit blower motor mechanism. Rotate blower motor manually. If rotate, check power to motor. If power is there, replace only fan-capacitor.
If hard to rotate, replace bearings or motor itself. If no power to motor, defective in PCB. Repair/replace PCB. Thanks and hope it's helpful.
Jan 22, 2011 | Heating & Cooling
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Outside unit fan not turning no cold air inside.
Ok here we go. It is possible that the capacitor for that fan unit is out or the motor for that unit is out. Without the proper tools i.e. an electrical meter, there isn't really a way to test the unit. The remote should not have anything to do with the unit activating if the is a manual thermostat. I suggest checking to see if either the motor has gone bad or the capacitor has bit the dust. If you have the motor changed make sure to replace the capacitor
Good Luck on your repairs hope I helped you some\
Dave
Jan 08, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Remote control functions Ok (ie display appears and settings can be changed), but the air conditioner unit does not respond. Can operate using ther manual switch on the inside unit, but does not get past...
Use your cellphone or any digital camera as your eyes by pointing the camera to the remote control transmitter. Light should emits on the remote control receiver. If no lights means defective remote control. But if lights emits means that either the receiver board or the main board is defective.
Try also the rst or reset button if present. Reset and try the remote.
Jun 02, 2009 | Heating & Cooling
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Hitachi RAS 5142CHA Won't operate
Check the fuse on the control board inside the head unit,if its ok you need to replace the contrl board
Apr 04, 2009 | Hitachi RAS-09UH Air Conditioner
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
