Question about HP HEWLETT-PACKARD DW065B ULTRIUM 232 EXTERNAL TAPE DRIVE U.S. - ENGLISH LOCALIZATION Tape Drive
How to configure or enable hardware compression in DW065B LTO1 Drive. When trying to take backup in H/w compression mode the tape (100/200 GB Tape) is ejected.
  • Anonymous Mar 12, 2014
    enable compression 2:1
  • 154 Answers
The L&TT support ticket contains drive configuration information such as whether hardware data compression is enabled or not.
Use L&TT to pull the ticket then look in the Drive->Drive Configuration section for details.
Here's an example:
|__ Drive
||__ Data compression : Enabled
||__ Current block size : Not available
||__ Detect WORM tampering : WORM not supported
||__ Reads after WORM tampering : WORM not supported
||__ Media removal (software controlled) : Allowed
If data compression is not enabled then it is likely that it has been turned off by the backup application. Check the options in your application to ensure that software compression (done by the server) is turned off and hardware compression (done by the drive) is turned on.
Data compression can be turned on in the drive by
  • The application ( the application will usually override the drive configuration so configuring the application correctly is of prime importance)
  • Resetting the drive
  • Power cycling the drive
  • Using the L&TT Set Drive Configuration utility (use the options to enable compression -see the L&TT user guide below)
NetBackup usersCaution NetBackup will turn off hardware compression in the drive at the end of each backup, so when you look at it with Library and Tape Tools it will be off. This is actually normal for NetBackup, so please check the configuration of NetBackup to make sure that compression is configured correctly. In this case see 'Measure Compression Ratio' (go back one level) as that will show whether compression has been in operation in the drive.
Click here to download the free L&TT utility (www.hp.com/support/tapetools) - this will also access the L&TT user guide
Use the L&TT FAQ to find out how to pull a ticket.
Click here for the L&TT FAQ. (www.hp.com/support/lttfaq) Look for How do I generate a support ticket? in the contents.
Posted on Aug 12, 2010
LTO1 error code 4
The LTO 1 error code 4 means "A firmware or drive problem has occurred."
You might try reflashing your firmware, which you'll find here.
I hope that helps.
Mar 14, 2011 | IBM (08L9762) LTO 1 Tape Drive
My Backup HP Tape Drive 232 flusing led "Cean" and "Tape"
This can often be resolved by loading a Cleaning tape. Cleaning tapes are specific for the LTO1 and can be used only a set number of times. This can be caused by a particular tape which is imparting contaminates into the drive. LTO drives should be cleaned when the light flashes only and not after a fixed number of hours.See the HP LTO1 user guide for details.
Jan 11, 2011 | HP StorageWorks Ultrium 232 LTO 1 Tape...
Anytime I try to backup or copy a 33GB data file on a 40GB or 72GB Data cartridge, it requests for more data cartridge even after formatting the data cartridge prior to starting the process. Sometimes, the...
Because the DAT72 can copy 72GB with 2:1 compressed, and it's native capability is 36GB in the most. So you can try to copy less than 30GB data to it or try to enable the drive's compress mode.
Nov 26, 2010 | HP StorageWorks DAT 72 Tape Drive
Symantec Backup Exec 11d compression
Unfortunately, the data types you described are already compressed.
Your hardware and software cannot compress it any further. In fact, compressing compressed files actually increases the file sizes. Don't worry, Backup Exec knows better than to compress compressed files so you can leave your settings in place.
The compressed capacity of a tape drive is a marketing ploy by the tape backup industry to make them more appealing. Yes, if your backup consisted entirely of uncompressed files you might get close to 75GB but never 80GB. You can only count on getting the uncompressed capacity of a tape.
Three options:
Obviously, a higher capacity tape drive will resolve this problem.
You could also swtich to using two tapes but you would have to load the second tape when you arrive for work in the morning and your backup would have to finish during the business day.
Finally, if you have some data that does not change frequently you could seperate it from your active data. Backup the active data on your regular backup. Now you can backup the "archived" data manually with a separate backup job. Once backed up you only have to back it up again when new data is added to the archive.
I hope this helps.
Jul 21, 2009 | Symantec VERITAS? Backup Exec 11 for...
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Pc Freezes when attempting to access HP SSL-1016 Ultrium 460 Tape
I have to admit this is a tough one. You seem to have tried most things i would try 1st.
I would suggest trying to download an eval coy of another backup program such as backup exec 12.5 from the symantec website and trying that.
This enables you to eliminate the backup software from your enquiries and if you also enable BUEX to use its own drivers (rather than the standard windows drivers) then that is another thing eliminated.
http://www.trilan-it.com/ are pretty good near the Berkshire area if you need a field call to help sort the issue but i would try BUEX 1st as that will help diagnose the problem even if you dont wish to continue with their software
Apr 16, 2009 | HP StorageWorks 18 Ultrium 460 Autoloader...
Backup software for certance travan 40?
You will have to load a driver for the Travan drive, if windows server 2000 sees the tap drive you could use NTbackup.exe to configure a back-up here is a link to read more about it. http://support.microsoft.com/kb/237310/
Good Luck
Jan 28, 2009 | Certance Travan 40 GB (stt3401a-sst)...
Backup Problem
80GB is the non compressed and 160GB is fully compressed. Based on my experience youll never get a compression rate of more than 1.5 to 1, so you should expect to get more than 120GB on the tape.
The issue that you are having is that you are using the drivers that either are built into windows or came with the tape drive and not the driver from symantec.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 09, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
Media is not inserted: tape backup
it's HPE day, why post to fixya for HPE , enterprise level products?
no pc stated
no sever stated.
no exact products stated,just symanted? what is that? ah Symantec tape backup software.version?
hp lto1 with scsi adapter
what model LT01. what model scsi adapter make and model.
hp makes vast versions of that drive
like (wild guess)
HP Q1515A
C7401-60024
StorageWorks Ultrium 230 LTO 1 Tape Drive
SCSI LV/DS
Q1516A
try a new tape yet, be wise, no?
never own only 1 tape, and always have 1 spare new on shelf
of the tape runs via the scsi port, ok , all but the error works.
then it is not the scsi card .
tape first.
then get the drive rebuilt.
keep a spare drive on hand after all, is not backup a key function in any data center./? or small business, be ready?
Jan 10, 2018 | HP Computers & Internet
HP HEWLETT-PACKARD DW065B ULTRIUM 232 EXTERNAL TAPE DRIVE U.S. - ENGLISH LOCALIZATION Tape Drive Logo
363 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
