Question about HP PSC 1315 All-In-One InkJet Printer
I just got new ink but it still says check print cartridge. what gives?
  • 83 Answers
If u have refilled ink in old trial caritridgethen this message occur every time ignore it. it nothing.
Posted on Aug 03, 2010
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
How do i change an ink cartrige in a canon 160 printe
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Sep 06, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
Printer will not print text. will only print picutres and graphics and text on graphics. just replaced the black and white cartridge.
It sounds like you are either out of black ink or you have a clogged black printhead. Perform a nozzle check/test page, then do 3-4 printhead cleanings. Run another nozzle check/test page and compare it to the first one. If you see improvement, keep cleaning your printheads until the black printhead is unclogged. If you do not see any improvement, you may need to replace the black ink cartridge. (I am assuming that your printer uses a tri-color and black ink cartridge) Replacing the ink cartridge will give you a new printhead (attached to the ink cartridge).
Jul 05, 2010 | Computers & Internet
It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
Jan 16, 2010 | Apple HP DeskJet 840c InkJet Printer
Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
Prints everything blank
Check the print cartridge. Open the printers top cover and find release lever for the ink cartridge. Lift out the cartridge and check the jets (copper coloered foil with holes) for blockage. New cartridges have a piece of tape over the jets which must be removed before installing. If blocked with dried ink, dab gently with paper towel and rubbing alcohol. Dry by dabbing on paper towel. Other things to check are: Incorrect cartridge, empty cartridge, and cartridge not snapped in all the way. The cartridge that comes with the printer usually is only partly filled and runs out earlier than normal. You could always try a new cartridge which you will need eventually anyway.
Good luck,
Techjoel
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Installing new ink cartridges
Be sure you have snap the ink cartridge tight, and check the expiration date of the ink cartridge.
Nov 12, 2008 | Dell Office Equipment & Supplies
HP PSC 1315 All-In-One InkJet Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
