Question about HP Pavilion dv6000z Notebook
I hear a loud static noise when I connect my laptop to my tv. I have a HP Dv6000 laptop and when I hook it up to my Olevia lcd flat panel tv using a VGA for the video and mini jack with a rca adapter. I plug the red and white into the back of the tv. I hear a loud static noise. When i unplug the charger from my laptop the static noise goes away. Can any one please tell me what is causing this
  • HP Master
  • 12,061 Answers
You have whats called an earth imbalance, you may indeed find that you need to ensure BOTH ends are earthed, usually via the cable, but some/most adapters are above earth and cause this problem, all i can suggest is to try a new adapter, and make sure you have good earths between the two units, via the Audio cables. The reason it works OK without the PSU, is there there is then NO earth connected from the mains..
I have found sometimes that this symptom is indicative of a bad earthing of the House/mains wiring too. This is common if ion a dry climate, you may need to earth out your system better, or just use batteries when doing this?
Posted on Aug 03, 2010
My olevia 237-t11 turns off by its self and sometimes makes a loud screcheen noise
Sounds like either the main or display power supply is failing. Might consider a new TV. Parts could be found but it might be hard to find them.
Aug 28, 2014 | Olevia 237T 37 in. LCD TV
Loud static noise without warning
this problem come due to memory ic faulty contact service centre for memory is
Jun 04, 2010 | Philips 47PFL7403D 47 in. LCD TV
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
Olevia 32" lcd tv made a loud, popping noise, shut off & now it won't come back on. When it popped, I noticed a spark
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Feb 03, 2010 | Olevia LT32HVM 32 in. LCD Television
How do I hook up a ps2 to my olevia tv
Audio out of your PS2 RED and WHITE connect it to your Audio in of your TV and Video out of your PS2 YELLOW connect it to your TV's Video in. YELLOW.
Oct 02, 2009 | Olevia LT32HVM 32 in. LCD Television
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
HP Pavilion dv6000z Notebook Logo
514 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
