Question about Boating
Need a service manual for mercury 500 50 hp 4 cyl outboard
5 Suggested Answers
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at j_speaks@yahoo.com.
Posted on Jun 16, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
canbruce75
  • 1776 Answers
SOURCE: how to service a tilt/trim on a 50 hp yamaha
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Posted on Aug 31, 2009
Looking for a 2016 tracker targa V 18 combo with a 150 HP murcury 4 stroke outboard engine owners manual
Manual is in the first link
Mercury 150 FourStroke Manual
https://dmna.ny.gov/nynm/manuals/Mercury_150_FourStroke_Manual.pdf
RCD-H-2 Rev 4. 150 HP 4-stroke (3.0L) hp. OP401000 or. 1B227000. RCD-H-2 Rev 4. Essential requirements. Standards. Other normative document/ method ... Owner's manual. This declaration of conformity is issued under the sole responsibility of the manufacturer. I declare on behalf of the engine manufacturer that the ...
Owner's Resources ' Mercury Marine
https://www.mercurymarine.com/en/au/service-and-support/owners-resources/ The major consideration in preparing your outboard for storage is to protect it from rust, corrosion and damage caused by freezing of trapped water. Outboard Storage tips ... Mercury Authorised Dealers have the expertise and training to handle all of your engine maintenance service and needs. Engine Maintenance.
FourStroke 150 hp ' Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/150-hp/ The specifications displayed here may not be indicative of the entire engine family; click on the "See All Models and Specs" link to view the specs in detail. ... Perfect for Repower. The compact, lightweight design of the Mercury® 150hp FourStroke engine fits most transoms, including those with narrow engine wells and tight ...
Outboard Care ' Mercury Marine
https://www.mercurymarine.com/en/ca/landing/outboard-care/ Step-by-step videos to help you maintain your 150 hp FourStroke. Flushing; Oil change ... This helpful how-to video shows you how ensure your outboard motor is maintained for peak performance. Here are step-by-step ... FourStroke engine. For more information, please consult your Mercury Marine owner's manual.
150 HP Mercury 4 stroke outboard engine owners manual Google Search
Dec 06, 2017 | HP Boating
How do I remove the mid section on a mercury four outboard engine
Hey Dennis,
What has happened to this engine that requires the Driveshaft housing to be removed? Please give more info/details in a reply to me. Thanks!
I need model/year/HP.. etc..etc..
https://www.marineengine.com/parts/mercury-outboard-parts/100-4-cyl/0g760300-thru-0g965520-usa/driveshaft-housing-usa-0t801000-bel-0p268000-and-up
Jun 04, 2017 | Mercury Boating
Where can I find a free service manual for a mercury 7.5 hp outboard
try going google and typing in--- workshop manual for mercury 7.5 hp outboard engine --- and if there is a pdf version then download it
otherwise it will not be free
Sep 24, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
I'm looking for a downloadable version of the service manual for this motor. Any Ideas? It's a 1994 mercury XRi 175 hp outboard
I couldnt find one anywhere for my merc 75hp 2stroke-ended up buying a service manual $70
Oct 09, 2009 | Boating
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Boating Logo
77 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
