Question about Asko W6021 Front Load Washer
Motor Fault F6 Motor Fault signal. Water fill OK. Then the drum won't turn. Drain OK. No spin. My model is not mentioned below and the instruction booklet says: 20605
  • BONGOTX May 11, 2010
    I HAVE THE SAME PROBLEM WITH THE SAME MODEL.
  • Motor Fault May 11, 2010
    Actually, I am unlikely to receive a response to the problem because my Washer is 20605 and there was no catergory listed.
    If you can help by telling me how best to get this repaired it would be good.
    I am still trying to find out which part would be needed when the signal said: F6
    Sergeant:
  • 351 Answers
Check the carbon brushes on the motor or it can be a motor fault also change the belt at the same time
Posted on Aug 27, 2008
Buttons all work but drum will not spin and it shows code f01
You dont mention make! Does it start program then shut off or does it fill then not turn? First part of any program is to pump out any water left from it previous program .if something is blocking pump (bra wire/coins/hair bobble etc) it will shut down and putup a code.if its the brushes in the motor or belt broken it will start then pump then fill then may carry through whole program as it doesnt know its drum isnt spinning.or it will detect and show fault code.replacing brushes in motor is for somebody who knows what theyre doing.but its straight forward and brushes are cheap. Pumps blocking again common but most people can clear a blockage via a door at bottom of machine.water will ome out so take drain tube and hold in a bucket at ground level first
Jan 18, 2016 | Amana Dryers
Drum wont turn, Do I need a belt?
If motor turning, belt slip, bearing could be broken. It's not easy to change the bearing, but first try spin the drum, if it can spin freely, then tighten the belt tensioner by adjusting the motor mounting screw.
Oct 07, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore 800 washer won't start and fill with water
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Feb 12, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Washer won't agitate, spin, or drain, but will fill
Jan 23, 2013 | Washing Machines
Model ge wlsr2200j5ww washing maching won't drain or spin
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jun 26, 2012 | GE Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
SPLENDIDE WASHER PROBLEM
Mar 14, 2012 | Washing Machines
Fills with water drum turns a few times stops. lights start flashing. checked filter. ok machine is a hec
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Aug 02, 2011 | Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Asko W6021 Front Load Washer Logo
270 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
