Question about Home
Well pump in the house seams not to be holding pressure for very long
  • 760 Answers
I'm assuming this is not for a bath tub actually. You're referring to your well pump. The problems are different if it is a submersible deep well or an above ground shallow well pump. In either case if you have a suction leak, the pump will short cycle. Or if you have a plumbing leak the pressure will slowly drop off until the pump cycles, and re-pressurizes the system. Or if you mean when you begin to use water the pump comes on quickly, check your expansion (bladder) tank. If it has a leak in the bladder it won't do it's job. Turn water off. Check air pressure on air fill valve on tank. Your tank should indicate what pressure (usually about 20psi, tank empty of water.
Posted on Aug 03, 2010
My submersible pump holds at 40lbs of pressure but I loose water to the house, replaced pressure switch. What could be wrong?
Just a thought. Is your pipe to the house leaking? even if its a little bit will take pressure down. What about your taps or yes your toilet. It don't take much of a leak for pressure to drop. Make sure your toilet completely shuts off or flapper does not leak. I have seen that happen.
Sep 12, 2016 | Plumbing
Reduced pressure. Pump runs when handle released. Water leaking from the bottom of the machine when I have the wand handle open. When I release the handle, the leak stops. Thanks.
You should know if the pump has not been frozen by winterperiod example a tear in the pump housing , second if its not so there will be a for shure a cuff kit for it but the most important question is how old is the pressure washer and is it in your Country maybe cheaper then in Europe in most cases then go ahead but K?rcher is in most cases the budget commercial machines to expensive to replace spare parts because the price instead of new pressure washers with more technical futures by it and again garantee on it.
But the expensive models are 1600 rpm machines and have brass pumphouses they are made for every day use. and will not suprice spontaneous the user with leakage . then its comes slowly , but if anybody is using a pressure washer 1 or 2 times in a year is it a surprise if its working , ALTO NILFISK is a brand 90% i can tell you it will not function anymore by lime in the bypass of the autostop. all this aside you should take care on your pumphouse
pump and gaskets and cuffs hose connector o rings and important casting seams of the pump housing and hose connection. inspect it thoroughly but succes.
Oct 15, 2015 | Karcher K 3.450 1800 PSI Electric Pressure...
How to replace Fuel Injection Pressure Regulator on 2002 chrysler sebring
Fuel Pressure Regulator Removal & Installation To Remove:
  1. Spread tangs on pressure regulator retainer.
  2. Pry fuel pressure regulator out of housing.
  3. Ensure both upper and lower O-rings were removed with regulator.
To Install:
  1. Lightly lubricate the O-rings with clean engine oil and place them into opening in pump module.
  2. Push regulator into opening in pump module.
  3. Tabs hold regulator in housing.
Feb 12, 2011 | 2002 Chrysler Sebring
Pulsing when idle and when operating
I have the same Problem, there is a leak at a seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and if you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 12, 2010 | Karcher K2.26 Electric Power Washer
Pump leaking from base
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is about $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt to prove it,Karcher will replace the whole Pressure washer under warranty.
Jul 06, 2010 | Karcher K2.26 Electric Power Washer
Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 03, 2010 | Karcher K2.26 Electric Power Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
Karcher k 3.99 does not pause correct
Is there a water leak from the bottom ?
Is so, then there maybe a small crack in the seam of the plastic manifold pump housing or one of the connecting fittings. A New Manifold Complete about $61.00. You may purchase direct from Karcher, and replace if you are mechanically inclined.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
May 09, 2010 | Karcher K 5.85 M Electric Pressure Washer
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Home Logo
18 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
