Question about Canon EOS Digital Rebel XTI Digital Camera
Power light is on, biut nothing works
When I turn on the camera, the green light indicates that the camera is on, but nothing works. no display, no veiw finder, no flash, no menu, etc
  • 94 Answers
Main Pcb K fuse gone its need to replace other wise it want work.
do it with canon repair centre
Posted on Aug 10, 2010
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Nov 09, 2014 | Pentax Optio Cameras
No picture display or image when I turn the camera on
Did you try to press the display button on the back of the camera?
With the display button you can cycle through different things on the display. One is power save and it will display nothing. Perhaps that is everything you have to do. If that does not work, let me know.
Dec 16, 2013 | Canon PowerShot SX30 IS Digital Camera
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
My Nikon Coolpix L1 Digital Camera won't turn on but I do get an indication of the green light for a second but the lens won't extend..
hi there,
i had a similar problem, in that the green light would flash but nothing would happen,
best to try a brand new set of batteries, and if that doesn't work, the ribbon which brings power from the batteries to everythin else may not be connected fully. if you have the skill, or know some one with the skill, just open the camera up, and check all the ribbons (the power ribbon is identified generally as a green ribbon).
hope this helps :)
regards
Jan 18, 2010 | Nikon Coolpix L1 Digital Camera
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Not powering on
The manual indicates that the green light flashing once indicates that the camera is powering down.
http://www.manualnguide.com/dl/6597/ (see page 218 lamp indications)
The first thing you can try is to turn off the camera, remove the battery, remove the memory card. Hold for one minute , pop the battery in(but not the memory card) turn on the camera by pressing the power on buttn and holding it for 15 seconds. This will not only reset the camera but also force the motor to retrace/extend the lens if it is a lens related issue that is causing the camera to shut down.
Let me know if you need more help
Jun 04, 2017 | Casio Exilim EXZ75 Digital Camera
Black Screen
The blinking green power indicator means the unit is trying to startup but failing. You can try replacing filter caps in the low voltage power supply.
Dec 30, 2017 | Hannspree HC-194D 19" LCD Monitor
Sansung digimax s5oo
close the lens on the camera all the way!
Oct 15, 2006 | Samsung Digimax S500 Digital Camera
Canon EOS Digital Rebel XTI Digital Camera Logo
284 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
