Question about Panasonic Lumix DMC-LZ2 Digital Camera
BLACK SCREEN I opened up the camera as suggested and nothing seems to be unfastened. Any suggestions
I was finally able to fix it. It did take me a little longer than the 10 minutes as another as written:) I had trouble getting 2 of the little screws out, but finally succeeded. Then I saw the orange ribbon, but nothing seemed to be loose. At last I saw where it connected at the TOP, and pushed down the little black connectors which showed on both sides under the orange ribbon. I pushed it down as far as I could, put the back on the camera and turned it on! And it worked! Thanks so much for the tip. I am going to keep a little screw driver in the camera case along with the tip how to fix it in case it is a problem again!
Posted on Apr 26, 2008
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
Camera will not turn on, no signs of life at all. xmas present, opened, but hardly used. plugged into charger, still nothing. touch screen says black.
Hello :
First suggestion is to replace the battery . Because I think that the battery is dead [ can't be recharged anymore ] . If that didn't help , then the problem will be with the charger or the charging jack . If all that didn't help , then I would take it to the service .
Please don't forget to rate !
good luck .
Apr 07, 2010 | Nikon COOLPIX S7 Digital Camera
Black LCD screen. Nothing in LCD screen. No photo on card. When connected to computer, black images appear, no photo. Problem?
I took a hammer to the shutter - now it opens! Actually, I tried the suggestion and it did not correct the problem. I guess I will have to get a new camera. Very disappointed as this camera is only four years old and well cared for.
Jul 31, 2009 | Canon PowerShot A620 Digital Camera
Got the shutter and mirror clicks and err msg
bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Jul 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
My lens is stuck open
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Try
Apr 20, 2008 | Kodak EasyShare V1003 Digital Camera
Lumix TZ3 lens does not open
It is not clear if you are saying whole camera turns off or just screen turns off.
Notice before the camera went bad the lense does not extend in play mode, while it does in record mode. Many cameras have software that automatically turns camera off if lens cannot/fails to extend for some reason. Try to help it extend in record mode before camera turns off.
Feb 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
LCD is black
you can see images clearly? but no Menu items show is that what you mean? This would indicate a firmware malfunction. If you see nothing at all on the screen but only 'ghost' images then the back light has blown. Try first of all with the camera on tapping gently at the base of the casing in the region of the screen- this is where the connectors to the main board are. Contact The Minolta support team. If you are getting nowhere - I suggest the next camera - repairs are not usually an economic option if at all.
Jun 27, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
120 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
