Question about Sony Playstation 3 (PS3) Console
I have an HDMI cable and the av cable but when i try and hook up the hdmi like the manual says it still says i have no connection... i do have a 1080p t.v. so how do i hook it up to HD?
    President:
  • 1,139 Answers
Have you tried resetting the display back to standard definition by holding the power button down for 5 seconds and then going from there?
Hope this helps
Posted on Aug 03, 2010
Pc hdmi no sound
some televisions require a seperate audio feed from the HDMI cable to hook up audio. if you have the cables for this i would try that first. normally ends up having to go thru an AV connection
Jan 16, 2014 | Proscan Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
How do you connect the cable to the tv? I have a dvr box but dont know where the connection on the tv is?
Cable from box to t.v , from antenna to box . If you have a hdmi cable plug into the back of the box, and plug into the hdmi input on the back or side of your t.v
Jan 17, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
When i hook up a dvd player the screen is in black and white what is wrong i followed the manual?
U used the RCA component AV cable Y,R,W?Yes,the Yellow cable must have been damage,that the video out put cable.Ur DVD player have a HDMI port?Used the HDMI cable hook up for DVD player to ur tv HDMI port.HDMI cable better cable design.
Jan 15, 2011 | Sansui 19 in. LCD TV
How to Hook Up HD AV Cable?
High definition multimedia interface cables are a type of audio/video (AV) cable that hook between your electronic media component and television. HDMI cables allow transfer of high quality audio and video signals between devices with the use of a single cable. HDMI is widely used with current generation video game systems, Blu-ray video players, and high-end video playback hardware. In order to make use of HDMI cables, your television must be compatible with the proper HDMI ports present on the set.
First,plug the HDMI cable into the port located on your media device. Then Plug the other end of the HDMI cable into an available HDMI slot on your television.
Switch the output on your television to the HDMI slot you have the cable connected to.
Aug 12, 2010 | Televison & Video
Can not make connection . It work fine until my son try to hook it up to tv sytem in hotel.
dont try it with hdmi cable, use the av cable and plug into the normal tv, go change the setting in display setting back into hdmi, switch off and tryn with hdmi cable
Feb 28, 2010 | Microsoft Xbox 360 Console
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Sound keeps cutting out momentarily on ps3 connected to samsung plasma tv via hdmi cable
Make sure game disk is clean and scratch free. Try and hook up the video with original AV cables (Red,Wht,Ywl) and unplug HDMI.Try another HDMI cable. If none of these help you could have bigger problems. Good Luck.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
How do you turn on the HDMI cable, i have a 40 GB ps3 but i lost my owners manual and i try to change the video settings but it says the device is not turned on or hooked up...well i made sure it was...
It's automatic. You can't turn on the hdmi cable.
Have you tried to manually set it up under Settings --- Video / Display ?
Make sure you've got the av cables plugged in too so that you can switch over to the hdmi manually from that menu.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read my hdmi cable
first hook up the av cable then do your set up then powerdown then hook up your hdmi if not problem message back
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
