Question about Proform Exercise & Fitness
Replacing flywheel on the motor drive - Proform Exercise & Fitness
  • MONA STOUTE Aug 03, 2010
    i FORGOT TYO TELL TARAN, I WOULD LIKE TO REPLACE THE FLYWHEEL
  • 10,515 Answers
Kindly provide few details :-
1. Make and Model of the treadmill?
2. Explain the problem in detail?
Thanks!!
Posted on Aug 03, 2010
    my treadmill is a PROFORM PFTL49210-LX560
  • taran_2005
    taran_2005 Aug 03, 2010
    Thanks for your response!!
    The flywheel will have to be threaded off the motor shaft.
    If the replacement motor does not include a flywheel, remove the
    flywheel from the old motor and place it on the new motor. Hold the
    motor axle on the end of the motor opposite the flywheel with a pair of
    vice grips and twist the flywheel off. NOTE: The motor axle threads have reverse threading. Turn the flywheel clockwise to remove it from the motor.
    Note - For your guide though, on the Proform motors, the flywheel just unscrews, but it is right hand turn to remove, unlike a conventional nut and bolt. You put the back end of the motor in the vice, and made a small tool that would allow you to turn the flywheel with some tortion,. It would come right off.
    If you have any questions, revert and i would be glad to answer.
    Good Luck!!
    Thanks!!
    Genius:
  • 1,478 Answers
Park the vehicle on a level floor. Jack up the front, then the back, of the car to place one jack stand under four supporting frame points to carry the vehicle at least 24 inches off the ground to replace the flywheel.
Lift the hood of the vehicle and remove the red positive battery cable from the positive post of the automotive battery. Pull the loose cable end away from the battery and secure in place when you replace the flywheel.
Separate the drive shaft from the rear of the automatic transmission. For rear-wheel drive vehicles this involves disconnecting the universal joint where it secures to the rear axle yolk. Remove the two U-bolts and turn the axle until the universal jointsfrees from the yoke. Pull the drive shaft out of the tail housing of the transmission and place off to the side.
Loosen and remove the torque converter bolts that secure the transmission to the flywheel on an automatic transmission. Six bolts, three short and three long, will need to be removed with the use of one or two closed-end spanner wrenches. Each bolt should be loosened before being removed to eliminate pressure being applied to the remaining bolts unevenly after most have been removed. Protect the parts that are still good by using this procedure for all fasteners that have multiple securing points that need to be tighten or loosened evenly when you replace the flywheel
Take care.
Replaced starter not engaging to flywheel to start engine what could be problem
I need year--make--model?
Can you remove flywheel cover, where applicable, maybe you can see if starter motor is kicking out drive-gear to engage flywheel? Check the flywheel teeth.
As far as starter testing, you can usually take the starter motor off, lay it on the ground, hook up jumper cables properly from charged battery to starter motor, at the least, it should kick out the drive gear and spin. I have to talk in generalities because I don't know which vehicle you have?
Feb 05, 2018 | Cars & Trucks
1998 jeep grand cherokee starter. Not engaging to flywheel. Works fine when manually jumped from battery.
Sometimes I take the starter motor off the vehicle. Lay it on the ground, hook up jumper cables properly from battery to starter motor, it should do two things, kick out the drive gear and spin. Do you have a flywheel cover that you can remove and watch the starter drive gear engage the flywheel? Also, check the flywheel teeth.
Sep 25, 2017 | Jeep Cars & Trucks
I have a 99 dodge intrepid 3.2, I replaced the old starter with a new one and now the solenoid drive will not engage the flywheel, help me please
Did you check out the basics? Does the starter motor spin and kick out the drive gear? Did you check the flywheel teeth? Did the old starter motor use shims?
Dec 03, 2016 | Dodge Cars & Trucks
How to t6.3 drive belt adjustment
Afix the drive belt onto the drive motor flywheel, then force the drive belt onto the roller pulley by turning the roller
Dec 29, 2013 | Nordic Track NordicTrack T6.3 Treadmill
Starter makes a screeching noise sometimes just after the motor starts
Replace the starter before it ruins the flywheel. You have a worn out drive that applies to the flywheel. Flywheels are very very hard to change, in fact you can change 10 or 15 starters in the same time changing one flywheel
Jul 24, 2011 | 1997 Buick Century
My car is making a whinning noise when i try to start it and i won't start
Can you tell if the engine is actually turning over? My first thought would be that the bolts holding your starter on the engine have loosened and the starter is not making contact with the flywheel. Another possibility would be that the flywheel has lost some teeth. Safely jack up the car and see first if the starter motor is loose, if not, open the inspection plate under the flywheel and get a visual look at where the starter and flywheel come together. If neither seem to be happening, then the starter itself may need replacing.
Mar 04, 2011 | 1991 Oldsmobile Cutlass Ciera
I have a 1990 chevy 1500 4+4 i just put a different automatic transmission in it and the flywheel went out which was also just replaced. It ran fine for a couple miles then all gears went out.im out of...
the only thing that comes in contact with a flywheel is the starter. maybe the starter motor drive gear is coming in contact with the flywheel.
Dec 30, 2009 | 1990 Chevrolet K1500
Shearing of flywheel pin on starting 12 hp snapper
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
Oct 29, 2009 | Garden
Deck turns on but doesn't do anything else. Motor runs.
The main flat belt you describe is probably the capstan belt. The "flywheel" you describe drives the capstan. I don't know the model number of your deck (it would help if you could say what it is), but I'm pretty sure that the flat belt should go around the big flywheel and then around a motor pulley that should be very close to the flywheel. The motor should spin the flywheel even if the play/FF/RW buttons are not engaged. This might sound funny, but the other "O" ring belts might be very important (control motor belts) or not that important at all (tape counter belts)--it depends on the model number of the deck. One more thing: Every healthy capstan belt I've ever seen is NOT sticky and does NOT glom onto itself. That belt sounds like it is very old and needs to be replaced.
Aug 21, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Exercise & Fitness Logo
78 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
