Question about Dryers
My whirpool dryer 's belt was broke, I do not know how to put my new belt on, need a picture of it, please help. daisymarzolf@hotmail.com
    Genius:
  • 1,073 Answers
What is the model number
Posted on Apr 25, 2008
NEED TO REPLACE THE FAN BELT ON HAIER DRYER MODELHLP140E
Remove the lint trap. There is a bolt in the center. Remove bolt. Remove screws from crossbar and you can then replace the belt. I removed sensor and lifted drum out makes it easier. Pay attention to how black belt is thread if removed
Apr 04, 2014 | Haier HLP140E Electric Portable Dryer
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Need help putting new belt back on Admiral dryer model ADG 7005 AWW, possibly a diagram?
Hi bgpace02669..
To to this webpage to see a picture of how to route your belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 09, 2011 | Maytag ADG7005AWW Gas Dryer
My Dryer belt broke and I need to know if it matters which way the new one gos on.
Hi monster z da...
Yes it does matter which way the belt goes on, you need to make sure the grooves of the belt is down and fitting in the grooves of the pulley of the motor.
Go to this webpage and see a picture of how to route your belt if needed.
Free answer...Please take time to rate me
Jul 08, 2011 | Dryers
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
The belt is broken. How do I install a new belt.
Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
May 23, 2009 | Dryers
Need to get to belt on my whirpool dryer
TAKE FRONT OF DRYER OFF PLACE BELT OVER TUB @ THEN OVER THE PULLEYS MAKING A FIGURE 8 LET ME KNOW IF YOU HAVE ANY PROBLEMS
Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
