Question about Iomega Prestige 15TB (34474) USB 20 Hard Drive
NOT SHOWING UP IN MY COMPUTER
I have 1.5TB Prestige USB 2.0 Desktop Hard Drive. When I connect this hard drive to PC. It does get connect but its not showing as a drive in My Computer. I am telling you it is getting connect because when I right click on My Computer and go to Device Manager, It shows iomega hard drive. What should I do????. I did contact support in IOMEGA they first thought
its happening because of getting less POWER to it so they changed adapter but its the same...When I right click on My Computer and go to MANAGE and DISK MANAGEMENT, It shows me Unknown, Not INitialized and Unallocated space 3.86 GB.What should I do????.
  • 5 more comments
  • keyurshah170 Aug 03, 2010
    It was working fine before.....Suddenly drive is not showing up....I can't format as It has 150 GB important data in it....What should I do????
    I downloaded one software named as NTFS Data Recovery. According to this software the problem might be because of bad sectors. What should I do?
    I donloaded trial version of norton utilities. Now how I can clean,find,repair bad sectors?
    Ok. I will buy it.Let me see the cost of it. But What option I should select in Norton Utilities software?
    Need a favor....Can u give me your yahoo or gtalk id so that I can chat with you directly if you dont mind please.
    Ok I bought it. Now what should I do?
    What I got is version 14.5.0.118...There are six options in Front...
    1. Clean your Registry
    2. Manage your Services
    3. Clean your disks
    4. Manage your Startup
    5. Defragment your registry
    6. Windows Defragmenter....Now tell me what should I select???????????
    So are you suggesting me to buy or get the trial version of this "Recover My Files" software???????/
  • 11,800 Answers
Sorry to tell you but this appears as the hard disk inside your Iomega case has died . Last effort: take it out and plug it in directly in a desktop. In there open it in a testing program like
http://www.hdtune.com/    - the free version.
If you get some errors you will know for sure that the disk is good for the skip. If the disk is good then it was completely corrupted and must be formatted. To do this use
http://www.partition-tool.com/personal.htm
After that put it back in the case and it should work normally.
Posted on Aug 04, 2010
  • 12,061 Answers
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved. Also it often pays to reinstall in another USB port.
IF your drive doesn't show up after doing all this, then if you can take it to another machine, now try to use it on this new machine, if it works and all is good, then you have some sort of problem on your PC, it may pay to reinstall everything again, However if it Still indicates that it isn't initialized, then it may indeed be faulty. You may have no alternative but to try and format again..
Now another way to see if all is OK or not, is to open up the case remove the HDD and get a USB to HDD "Dongle" then using this see if you can make your drive work, it may simply be the USB interface on the HDD unit itself. If so, then you can still use it via the Dongle, or back it up via the dongle. Then you could get a new case and USB interface, hopefully it will not come to that.
Posted on Aug 03, 2010
  • 6,826 Answers
Https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=1235&p_created=1072727206&p_sid=UNZKhv6k&p_lva=500&p_li=
The above link goes to troubleshooting the drive when it seems to not get assigned a drive letter.
Also, it covers formatting the drive to work with windows.
I wish you luck on this.
  • 15 more comments
  • Duane Wong
    Duane Wong Aug 03, 2010
    I think that if all attempts in the link above are exhausted then I think you should recontact Iomega tech support to try to rectify the problem.
    Do you have a spare computer that you can try to hook the drive up to in order to save the 150 gb of data on it?
    If so, I would experiment with that possibility.
  • Duane Wong
    If there are bad sectors on it, then something could be wrong with the drive for it to do this so early in its life cycle.
    Does the NTFS program offer any help on trying to recover your data, even though there are lost sectors on the drive?
  • Duane Wong
    Have you considered using Norton's Utilities to recover bad sectors or to get data off of a defective drive?
    No NTFS Software is detcting bad sectors but I dont think this process will even finish because i started 2 hours back and still it shows 0% completed. Let me try the Norton way u said...
  • Duane Wong
    I hope you can recover the data with Norton's Utilities.
    I am downloading trial version of Norton Utilities from Norton website. Will that be fine?
  • Duane Wong
    Sure, that's a starting point. It may not have full functionality, though unless you register it.
    Its asking me to register it and purchase it. Do you have yahoo or gtalk id where I can chat with you directly if possible...that will be great help from you...Can i use trial version to finish my task????
    Do you have gtalk or yahoo id where I can chat with you directly....Its telling me to register it and purchase it...I can't use trial version to finish my task???????
  • Duane Wong
    I don't think that a trial version can help you complete the recovery of 150 gb of important data. They probably want you to register it to proceed with the recovery. If it is possible, then Norton's has a good reputation for recovering data on non bootable discs or partially damaged hard disks.
  • Duane Wong
    Did you get the latest version 14.0?
    There should be a recovery console in it, I read.
  • Duane Wong
    Symantec has released a version of Norton Utilities which is called Norton Utilities Premier Edition. It also Includes the features of the Norton Utilities plus the Norton Online Backup. It is also compatible with Windows 7. It was released on October 14,09
  • Duane Wong
    Norton Utilities (14.0)
    The revival of Norton Utilities as standalone software was announced on 2009-02-03.[25]
    The program supports Windows XP , Vista (32/64-bit).
    It includes Registry Defragmenter, Registry Cleaners, Disk Cleaner, Disk Defragmenter, Startup Manager, Service Manager, Restore Center, System Optimizer, Process Viewer, and Performance Test.
    The product licence was changed to allow it to be used on up to 3 household PCs
  • Duane Wong
    I don't use the Yahoo! or Gmail services.
    However, I've been reading up on the Norton's Utilities and it's becoming apparent to me that you might have had to have the program installed for backup before restoring files from the Internet.
    I would normally try the 'restore' option, but it may not let you if you haven't arranged to have files backed up before hand.
    I would hold off of keeping the Norton's Utilities program if it can't recover or restore your data that previously was not 'protected' by the program.
    Don't worry, I believe you can get tech support through Symantec and if they agree, you can get a full refund back.
    I'm sorry that it didn't work for you.
    I would try to contact the iomega group for further instructions on recovering that data, though.
  • Duane Wong
    http://www.symantec.com/norton/support/d...=
    I would use the above link to get a refund on this product if you don't think it will work for your situation where the files were not backed up online before hand.
  • Duane Wong
    http://www.recovermyfiles.com/
    The above link goes to a $69.95 program that you can download a trial version for free that will display any recoverable files on your drive. If this doesn't work, as far as showing the files on your hard disk drive, I don't know what will.
    The trial version is free and if you don't see any files or it locks up, I'm afraid that those 150 gb of files may not be retrievable.
  • Duane Wong
    If the trial version of the program shows the files that are recoverable off the 1.5 TB drive from Iomega, then I think I would purchase it. But, if it comes up blank, then I think the files are not retrievable.
    That is, first try the trial free version, and go from there. Use your best judgment, I guess.
    I can't say that I have experience with this particular program, but they seem legitimate.
I like to get the user guide for Iomega prestige 1TB
Prestige Desktop Hard Drive USB 2.0 User's Manual: View Online [HTML] ' Download [418KB zipped HTML]
Quick Start Guide [PDF 1.8MB]
Specifications
Nov 27, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
I have tried connecting my Iomega 250 gb USB 2 Hard Drive to my computer and it is telling me that the unit has malfunctioned. Is there any way of getting the data off it?
First try connecting this USB drive to a different computer.
If this did not work then the USB adapter case is faulty, then remove the hard drive from the case and attach the hard drive to an USB hard drive adapter then plug it into a working computer's US port. If the hard drive is OK then the computer will see this as an external storage device and you can open the folders and files to backup the data off this hard drive.
If this does not work then there are companies that can recovery data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 21, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Could not find pretige iomega icon on my computer
format the harddrive as MS-Dos to be able to use it on Mac and PC.
Apr 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
500GB Prestige USB 2.0 Desktop Hard Drive
Try using a different USB cable, also power off the drive and then replug in the USB cable and power up connected to computer.
Mar 13, 2010 | Computers & Internet
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
I've connected my 320gb prestige usb 2.0 portable hard drive to my computer, so now how do i transfer my file on to it?
Hello my friend,If you are a Windows user, your external hard drive will show up on the My Computer screen just like any other hard drive.Drag and drop (or copy & paste) the files you wish to back up on your external hard drive.That`s it:)
Feb 08, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Hi, I just bought iomega 1 tb select desktop hard drive, i have a laptop and i have connected to an USB but it is not showing up.
You may need to format the hard drive before you use it.
If your using a PC....go to Control Panel>Admin tools>Computer managemant.Disk Management....Create a new partition and format the drive (NTFS).
Using a Mac go to spotlight and type Disk utillities, partition the drive...
Oct 29, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Open Questions:
Get your wife husband back lost love spells caster in city of New York +27832762854 Have you ever been in a failed relationship? Did you often feel like your partner didn't 'get' you? Are you having many obstacles in your life? Is your love life falling apart? Is your life facing financial ruin? Do you need protection from your enemies? If you seek a lost lover, or want a new lover, we can help. We reunite lost lover`s If you are really in love with someone then this is the spell for you. divorce affairs all kind of witchcrafts bring back lost love spells in NHL Eastern Conference bring back lost love spells in Boston Bruins bring back lost love spells in Buffalo Sabres bring back lost love spells in Carolina Hurricanes bring back lost love spells in Columbus Blue Jackets bring back lost love spells in Detroit Red Wings bring back lost love spells in Florida Panthers bring back lost love spells in Montreal Canadiens bring back lost love spells in New Jersey Devils bring back lost love spells in New York Islanders bring back lost love spells in New York Rangers bring back lost love spells in Ottawa Senators bring back lost love spells in Philadelphia Flyers bring back lost love spells in Pittsburgh Penguins bring back lost love spells in Tampa Bay Lightning bring back lost love spells in Toronto Maple Leafs bring back lost love spells in Washington Capitals bring back lost love spells in Western Conference bring back lost love spells in Anaheim Ducks bring back lost love spells in Arizona Coyotes bring back lost love spells in Calgary Flames bring back lost love spells in Colorado Avalanche bring back lost love spells in Chicago Blackhawks bring back lost love spells in Dallas Stars bring back lost love spells in Edmonton Oilers bring back lost love spells in Los Angeles Kings bring back lost love spells in Minnesota Wild bring back lost love spells in Nashville Predators bring back lost love spells in San Jose Sharks bring back lost love spells in St. Louis Blues bring back lost love spells in Vancouver Canucks bring back lost love spells in Vegas Golden Knights bring back lost love spells in Winnipeg Jets bring back lost love spells in NBA Eastern Conference bring back lost love spells in Atlanta Hawks bring back lost love spells in Boston Celtics bring back lost love spells in Brooklyn Nets bring back lost love spells in Charlotte Hornets bring back lost love spells in Chicago Bulls bring back lost love spells in Cleveland Cavaliers bring back lost love spells in Detroit Pistons bring back lost love spells in Indiana Pacers bring back lost love spells in Miami Heat bring back lost love spells in Milwaukee Bucks bring back lost love spells in New York Knicks bring back lost love spells in Orlando Magic bring back lost love spells in Philadelphia 76ers bring back lost love spells in Toronto Raptors bring back lost love spells in Washington Wizards bring back lost love spells in Western Conference bring back lost love spells in Dallas Mavericks bring back lost love spells in Denver Nuggets bring back lost love spells in Golden State Warriors bring back lost love spells in Houston Rockets bring back lost love spells in Los Angeles Clippers bring back lost love spells in Los Angeles Lakers bring back lost love spells in Memphis Grizzlies bring back lost love spells in Minnesota Timberwolves bring back lost love spells in New Orleans Pelicans bring back lost love spells in Oklahoma City Thunder bring back lost love spells in Phoenix Suns bring back lost love spells in Portland Trail Blazers bring back lost love spells in Sacramento Kings bring back lost love spells in San Antonio Spurs bring back lost love spells in Utah Jazz bring back lost love spells in NCCA bring back lost love spells in Air Force Falcons bring back lost love spells in Alabama Crimson Tide bring back lost love spells in Arizona State Sun Devils bring back lost love spells in Arizona Wildcats bring back lost love spells in Arkansas Razorbacks bring back lost love spells in Army West Point Black Knights bring back lost love spells in Auburn Tigers bring back lost love spells in Baylor Bears bring back lost love spells in Boston College Eagles bring back lost love spells in BYU Cougars bring back lost love spells in California Golden Bears bring back lost love spells in Clemson Tigers bring back lost love spells in Colorado Buffaloes bring back lost love spells in Florida Gators bring back lost love spells in Florida State Seminoles bring back lost love spells in Fresno State Bulldogs bring back lost love spells in Georgia Bulldogs bring back lost love spells in Georgia Tech Yellow Jackets bring back lost love spells in Houston Cougars bring back lost love spells in Illinois Fighting Illini bring back lost love spells in Indiana Hoosiers bring back lost love spells in Iowa Hawkeyes bring back lost love spells in Iowa State Cyclones bring back lost love spells in Kansas Jayhawks bring back lost love spells in Kansas State Wildcats bring back lost love spells in Kentucky Wildcats bring back lost love spells in Louisville Cardinals bring back lost love spells in LSU Tigers bring back lost love spells in Maryland Terrapins bring back lost love spells in Miami Hurricanes bring back lost love spells in Michigan State Spartans bring back lost love spells in Michigan Wolverines bring back lost love spells in Minnesota Golden Gophers bring back lost love spells in Mississippi Rebels bring back lost love spells in Mississippi State Bulldogs bring back lost love spells in Missouri Tigers bring back lost love spells in Navy Midshipmen bring back lost love spells in Nebraska Cornhuskers bring back lost love spells in North Carolina State Wolfpack bring back lost love spells in North Carolina Tar Heels bring back lost love spells in Northwestern Wildcats bring back lost love spells in Notre Dame Fighting Irish bring back lost love spells in Ohio State Buckeyes bring back lost love spells in Oklahoma Sooners bring back lost love spells in Oklahoma State Cowboys bring back lost love spells in Oregon Ducks bring back lost love spells in Oregon State Beavers bring back lost love spells in Penn State Nittany Lions bring back lost love spells in Pittsburgh Panthers bring back lost love spells in Rutgers Scarlet Knights bring back lost love spells in South Carolina Gamecocks bring back lost love spells in South Florida Bulls bring back lost love spells in Southern Methodist SMU Mustangs bring back lost love spells in Stanford Cardinal bring back lost love spells in TCU Horned Frogs bring back lost love spells in Tennessee Volunteers bring back lost love spells in Texas A&M Aggies bring back lost love spells in Texas Longhorns bring back lost love spells in Texas Tech Red Raiders bring back lost love spells in UCLA Bruins bring back lost love spells in USC Trojans bring back lost love spells in Utah Utes bring back lost love spells in Vanderbilt Commodores bring back lost love spells in Virginia Tech Hokies bring back lost love spells in Washington Huskies bring back lost love spells in Washington State Cougars bring back lost love spells in West Virginia bring back lost love spells in NFL AFC bring back lost love spells in Baltimore Ravens bring back lost love spells in Buffalo Bills bring back lost love spells in Cincinnati Bengals bring back lost love spells in Cleveland Browns bring back lost love spells in Denver Broncos bring back lost love spells in Houston Texans bring back lost love spells in Indianapolis Colts bring back lost love spells in Jacksonville Jaguars bring back lost love spells in Kansas City Chiefs bring back lost love spells in Los Angeles Chargers bring back lost love spells in Miami Dolphins bring back lost love spells in New England Patriots bring back lost love spells in New York Jets bring back lost love spells in Oakland Raiders bring back lost love spells in Pittsburgh Steelers bring back lost love spells in Tennessee Titans bring back lost love spells in Super Bowl LII bring back lost love spells in NFC bring back lost love spells in Arizona Cardinals bring back lost love spells in Atlanta Falcons bring back lost love spells in Carolina Panthers bring back lost love spells in Chicago Bears bring back lost love spells in Dallas Cowboys bring back lost love spells in Detroit Lions bring back lost love spells in Green Bay Packers bring back lost love spells in Los Angeles Rams bring back lost love spells in Minnesota Vikings bring back lost love spells in New Orleans Saints bring back lost love spells in New York Giants bring back lost love spells in Philadelphia Eagles bring back lost love spells in San Francisco 49ers bring back lost love spells in Seattle Seahawks bring back lost love spells in Tampa Bay Buccaneers bring back lost love spells in Washington Redskins bring back lost love spells in MLB bring back lost love spells in AMERICAN LEAGUE EAST bring back lost love spells in Baltimore Orioles bring back lost love spells in Boston Red Sox bring back lost love spells in New York Yankees bring back lost love spells in Tampa Bay Rays bring back lost love spells in Toronto Blue Jays bring back lost love spells in AMERICAN LEAGUE CENTRAL bring back lost love spells in Chicago White Sox bring back lost love spells in Cleveland Indians bring back lost love spells in Detroit Tigers bring back lost love spells in Minnesota Twins bring back lost love spells in Kansas City Royals bring back lost love spells in AMERICAN LEAGUE WEST bring back lost love spells in Houston Astros bring back lost love spells in Los Angeles Angels bring back lost love spells in Oakland Athletics bring back lost love spells in Seattle Mariners bring back lost love spells in Texas Rangers bring back lost love spells in NATIONAL LEAGUE EAST bring back lost love spells in Atlanta Braves bring back lost love spells in Miami Marlins bring back lost love spells in New York Mets bring back lost love spells in Philadelphia Phillies bring back lost love spells in Washington Nationals bring back lost love spells in NATIONAL LEAGUE CENTRAL bring back lost love spells in Chicago Cubs bring back lost love spells in Cincinnati Reds bring back lost love spells in Milwaukee Brewers bring back lost love spells in Pittsburgh Pirates bring back lost love spells in St. Louis Cardinals bring back lost love spells in NATIONAL LEAGUE WEST bring back lost love spells in Arizona Diamondbacks bring back lost love spells in Colorado Rockies bring back lost love spells in Los Angeles Dodgers bring back lost love spells in San Diego Padres bring back lost love spells in San Francisco Giants
Aug 20, 2018 | Sun Computers & Internet
See all Iomega Prestige 15TB (34474) USB 20 Hard Drive Questions
Iomega Prestige 15TB (34474) USB 20 Hard Drive Logo
125 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
