Question about Dolphin Maytronics Advantage
My dolphin works for a few seconds, then stops. The transformer is OK because it works for my spare dolphin. What is the remedy?
  • admcr Aug 03, 2010
    Yes, the solution was helpful. I will check the voltage and try again when the sweep dries out.
  • 12,061 Answers
I imagine that even though they are meant to be water tight, some moisture may have gotten into the unit and caused problems. Unfortunately there could be many many things that can cause these units to stop working.. From my experience there is little a home serviceman could do other than check all the obvious things. I recommend that you contact the manufacturer and ask for a referral to a n authorised service center, then when there ask for a "Quote" before proceeding with any repairs, that way at least you can get an indication of costings before you start.
Check for Voltage at the unit also, if you have the equipment and are so inclined.
http://www.maytronicsus.com/en-us/residential_pool_cleaner/dolphin_advantage_-_residental_pool_cleaner/
Posted on Aug 03, 2010
Dolphin diagnostic motor replacement
May be the circuit board - There is an on-line group called Circuit Board Medics who can test and repair the board.
Jun 22, 2012 | Dolphin Maytronics Diagnostic Robot...
Hi, my smartpool dolphin robo doesn't move any more. It seems stuck on the ground. When I 've started to understand why, i've discovered that out of the water, the wheels turn few seconds in...
There are two things that you can check yourself if these pool cleaners are not moving properly. First, check the impeller. Make sure that the transformer is unplugged and take the top grill off by removing the 2 screws from the top. Check for debris and remove if you see anything. Replace the grill and tighten the screws before you try the cleaner again. Also, check your front and rear wheels. Debris and leaves can get caught in the axle bearings. Make sure this is not the case. If one of these does not solve the problem, it could be your gear box and you will have to have it serviced by a professional.
May 19, 2011 | Smartpool Dolphin Robo - Kleen Above...
On starting, tracks roll one way for a few seconds, then reverse for a few seconds then stops with no further movement. Pump impeller does not move during this time. Impeller can be rotated by hand. No...
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dec 14, 2010 | Dolphin Maytronics Diagnostic Robot...
Dolphin vacuum. Turn switch on and it turns about 2 times,stops for a few seconds, and then turns about 2 times. This goes on for 3 to 4 times then stops and does not turn again. What are some...
Your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
John
Aug 06, 2010 | Dolphin Maytronics Advantage
Dolphin works for about 5 minutes and then stops.
There are a few trouble shooting tips you can try for these automatic pool cleaners, but if none of these work, you will want to take it into a professional. The impeller could be blocked, causing it to shut off. Clean the impeller and look for any obstructions. You drive system could be catching. Clean the tracks and wheels. The other problem would be with your electrical system. This is where you need to take it to a pro.
Jul 10, 2010 | Dolphin Maytronics Advantage
THE DOLPHIN STARTS AND WORKS FOR 20 SECONDS ABOUT AND THEN STOP. IF PLUGGED AGAIN 10 MN AFTER SAME PATTERN HAPPEN .
It can be an issue within the power supply, cable, motor unit or some combination of the three. For repair service you can contact the US rep at www.maytronicsus.com or if you are in the midwest you can send it in directly using our Dolphin service request page found at www.arrowpools.net.
Nov 10, 2009 | Dolphin Maytronics Advantage
The robot only works for about 10 minutes then stops.
For warranty and non-warranty repair service contact us using the dolphin service form at www.arrowpools.net or you can try the manufacturer at www.maytronicsus.com.
Jul 20, 2009 | Smart Pool Inc Dolphin Diagnostic...
Stops after a few feet
It can be in the power supply or the motor pack. You can contact us using the dolphin service form at www.arrowpools.net or try the manufacturer at www.maytronicsus.com.
Jul 16, 2009 | Smart Pool Inc Dolphin Diagnostic...
Circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Jun 13, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Maytronics  Advantage Logo
44 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
