Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I am needing (or at least I think) to reset my router. How do I go about this without the original disk? Thanks!
    Scholar:
  • 72 Answers
There should be a button on the back of your router that may or may not be labeled. You will need a small object (i.e., paperclip or pin) to press it. Hold it down with the power on, and your lights will most likely change indicating a success.
Posted on Aug 03, 2010
Belkin Startup Disk missing
The startup disc is not really required on most home wireless routers. Simply connect the ISP modem to the main port on the router and connect the pc to any other port. You should have internet via wire at this point.
You will have to reset the router by holding in the reset in the back till it cycles. This will clear all custom settings. Then simply use the defaults to log into the web admin if need be, or to setup a wireless key for protection.
Feb 11, 2013 | Belkin (F6D42304) Wireless Router
I reset my router, so I lost my security. Can I secure it again with out the disk that came with it?
Yes you can. I will demo it done with a Cisco router. It shouldn't be much different.
Jan 27, 2013 | Belkin Computers & Internet
I messed up my login passwords how can I reset?
I think you should try to reset the router to factory default settings and reconfigure it manually.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it manually.
See how to reset Linksys router
See Linksys router setup
Jan 16, 2012 | Linksys Wireless-G WRT54G Router
If i reset router without disk will my other ipods still work and newone without vizios password
If you hold down the reset button on the router, this will wipe out any settings on that router. Once you have setup the router you will merely need to enter the new password for each wireless device you connect.
You don't really need the disc to setup any router. Check out Chapter 3 "Setting Up Your Router" http://70.168.148.201/documents/downloads/accessories/XWR100/549XWR100%20User%20Manual.pdf
Comment back if you need more assistance.
Aug 17, 2011 | Vizio XWR100 Wireless Router
I need reset the default password for a symbol WS5100
Forgot your Windows password? A Windows Password Reset Disk could do all the job for you, it can reset your lost or unknown Windows password safely and quickly without login, you can create a Windows password reset disk with the tool Windows Password Breaker, then use it to reset your password.
Dec 12, 2010 | Symbol WS 5100 Wireless Switch - P/N...
New computer; can't find original installation disk
You should not need an installation disc.
Connect your PC to the router with a network cable and type 192.168.1.1 into the browser adddress bar. This will connect you to the router setup and maintenance screen, from where you can configure the router. If necessary you can reset it to factory settings and enter a new password.
You can then disconnect your cable and use it wirelessly.
Apr 09, 2010 | Linksys Wireless-G WRT54G Router
Installed dlink router but wireless connection keeps going offand keeps saying acquiring network address.
Hi there, this issue happens if your computer cannot acquired IP address from the router. please test your router first if other computers can connect to it. If Yes, then theres something wrong with your computer wireless adapter. in order to resolved this issue is try to reisntall the drivers of your wireless adapter. it is usually located at the driver disk that came with the system. If other computer cant connect also to the router then there is something wrong with your router. sometimes alll you need to do there is restore the router from original factory settings by pressing the reset key. if same issue happened after reset then you have to call your routers manufacturer for possible replacement. thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 06, 2010 | D-Link DGL-4500 Wireless Router
My cd disk drive is broken how do i install my
First reset all settings of router to default.
You can reset it with RESET button it is in back side of router press It for 10 seconds.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then configure your router WAN settings as your internet service provider settings.
Go to wireless enable wi fi .
Then save all settings then check.
Also enable DHCP if you want ip addreses automatic from router.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | Computers & Internet
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
Wireless G Broadband Router
Some thing like that happen to me my old laptop had a wireless (g) card in it and my router was a (g) the new laptop did not require a card. the new system is (n) so I had to buy an (n) router and a wireless (n) card. Although I think the (n) router will work with a (g) card. also if you have a disk you might have put a pass word on it during the original install. but you can always try to reset the modem and router simply by removing the power sourceor useing the reset buttons..Good luck
May 12, 2008 | Linksys Wireless-G Broadband Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
65 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
