Question about Kodak EasyShare C160 Digital Camera
I have a kodak easy share c160 and when i take a picture it displays on the screen really bright and it has vertical lines all the way down the whole picture, it just started doing it one day and i have no clue why, BUT if i set it to burst mode the pictures look fine, but you cant use the flash on burst mode...PLEASE HELP!!!
  • l_uknowuluvm Aug 03, 2010
    ok i took out the memory cand out and blowed the air in there and all around the lens and every hole i could find and it is still doing it..but thank you for trying!
  • Kodak Master
  • 6,826 Answers
Remove the card and blow compressed air in the chamber in order to clean any dust that may have gotton onto the card's contacts.
Also, try to reset the camera from the menu if it has this option.
If you can't use flash on burst mode, then this is not a solution.
Posted on Aug 03, 2010
I am trying to take pictures with my Kodak Easy Share C160. Everything was fine until a message saying "internal memory is full" came on. I have a memory card and have emptied (I thought) the...
When the memory card is in the camera, you see the card contents, not the internal memory. Take the card out, then delete all the photos you can find. The camera needs space on the internal memory to work, even if the memory card is empty.
Nov 22, 2010 | Kodak EasyShare C160 Digital Camera
Kodak easy share series 3 , only prints lower portion of picture.
Try reinstalling the printer driver. If that doesnt help, try a hard reset: Unplug the printer from AC power and PC, wait about 10 minutes and retry.
You can also do an alignment test. If none of this proves succesful, you either have a bad print head, or problem in the circuitry, which will need servicing.
Jun 24, 2008 | Kodak Office Equipment & Supplies
Needhelp with installation of Kodak easyshare on 7.0 system
This is the instructions on how to remove existing ESS system in order for you to start on a fresh.
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Feb 08, 2010 | Kodak EasyShare C160 Digital Camera
How do I change language from Spanish to English on my new Easy Share C160 Kodak camera
Press menu and select Configuración and then select idioma and then select Inglés and you should be back to English!
There is also an extended user guide available for your camera on the below link!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00964/C160_C180_xUG_GLB_en.pdf
cheers!
Dec 30, 2009 | Kodak EasyShare C160 Digital Camera
Not camera smart trying to figure out new camera and there is not enough directions kodak easy share camera
Type to connect to the following web page. It has many Kodak camera manuals. www.kodak.com/global/en/service/publications/index.jhtml
Dec 29, 2009 | Kodak EasyShare C160 Digital Camera
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Can't send videos/pics from kodak easy share software
The Kodak Easyshare software just index the pictures they do not store them at all
you can locate the pictures on the computer by
Click start
then look for search
type in in the search box *jpg
And it will display all the pictures that you have on your computer
To fix the problem regarding the easyshare software try uninstall it from your computer
Then download the clear utility www.kodak.com/go/clear
then download the latest version of the easyshare software www.kodak.com/go/easysharesw
Feb 19, 2009 | Kodak EasyShare C613 Digital Camera
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Open Questions:
See all Kodak EasyShare C160 Digital Camera Questions
Kodak EasyShare C160 Digital Camera Logo
67 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
