Question about Electrolux Epic 3500 Vacuum
How do I chanage the duct hose on an Upright Epic 3500 SR ?
SOURCE: electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
Posted on Nov 05, 2008
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
Vac Belts
  • 701 Answers
SOURCE: how to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Posted on Oct 29, 2009
SOURCE: Does anyone know how to get the bottom off the
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Posted on Dec 13, 2009
Testimonial: "Thanks so much Jim"
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Posted on Jan 30, 2010
How to change belt electrolux epic 3500 sr
See my other posts for the directions for change. Hope this helps!
Jun 19, 2014 | Electrolux Epic 3500 Vacuum
I need an Electrolux EPIC 3500 SR Manual. Can I download one on line? Judy Lewis
Hello Judy,
Below is the link for the manual you are requesting:
http://www.manualsonline.com/mdownloads/71312b47-cc60-4884-e1fe-e29af72fcfa1.PDF
Please let me know if you have any questions or concerns. Please rate this!
Thanks,
~PCF
Mar 15, 2011 | Electrolux Epic 3500 Vacuum
How to replace the flexible hose between the upright and floor modules?
Turn the vacuum on it's side. Pull the power nozzle end out. Unscrew, in a clockwise direction, the hose from the body/tank.
Reverse to install new hose. Screw the hose into the tank, turning counter-clockwise. Place other end into power nozzle. Ensure it's set properly.
Dec 31, 2010 | Electrolux Epic 3500 Vacuum
I have an Electrolux Epci 3500 Sr upright vacuum cleaner ... 100 percent positive switch is shot and one of the wires inside is fried but before buying a new handle assembly online how do I check the...
The switch is replaceable, so you don't need to replace the complete handle assembly. I've got a 3500 that I replaced the switch on and it works great now. You can get a new switch at the local Aerus Electrolux store. To find the nearest store, just follow the directions on the below site.
I do recommend letting the service tech do the replacement.
http://www.aerushome.com/storelocator/
Nov 26, 2010 | Electrolux Epic 3500 Vacuum
What kind of bag for the epic series 3500 sr
"U" (upright) style bags, available at any Aerus Electrolux store, or from their consultants. These are the genuine bags made only by Home Solutions. Generic bags WILL decrease the lifespan of the motor.
Contact your local dealer. Free home delivery.
Nov 15, 2010 | Electrolux Epic 3500 Vacuum
I would like to know how i get the very bottom piece off my vacuum off so I can put a new fidder hose on it? The hose is black and it is only about six inches long. its lacation is on the very end of the...
You don't have to take the vacuum apart.
Assuming this is an Epic 3500 or similar upright Electrolux:
1. Lay vacuum on it's side.
2. Gently pull hose from power head. It's not screwed in so that should be easy.
3. Unscrew it from the upper portion of the machine by turning the hose clockwise. Turning counterclockwise tightens it.
4. Remove it.
5. Screw one end into upper portion of vacuum by turning counterclockwise.
6. Insert other end of hose into opening in power nozzle. Some manipulating may be necessary for proper fit, but this is all that's needed.
Sep 22, 2010 | Electrolux Epic 3500 Vacuum
I have the electrolux epic 6500 sr. when i
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
How to check the belt?
Manual
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
Electrolux epic series 3500 sr serial v87779 l
John
Aug 16, 2008 | Vacuums
Vacuums Logo
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
