Question about Sharp AR-M162 All-In-One Laser Printer
I have an error code displayed on the copier as, H5-01 Please can you help/advice on the reset code which i could use.
    President:
  • Sharp Master
  • 1,447 Answers
When your copier heater unite thermostat is out of order then show H5-01 is blinking.
You can reset it Press # interrupt 0 Interrupt press 14 press print key or start button then machine is ready.If are not success you must change it.
Posted on Aug 08, 2010
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
I have a Savin 9113Z copier that is giving me a error code of 54. Any advice
Hello sir; You do need to reset this error code, procedure as follow;
press 71,hold down "clear/stop"key, until you see the "." in the upper left cornor of the display, then release, after that you press "clear/stop" key again then press lighter key, the 5 will now flash on the display, now enter 97 press start, turn machine off and back on , machine should be running.
Jan 04, 2010 | Savin Office Equipment & Supplies
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
7735
What are you tring or want to reset? Try the rest botton on the control pannel. Or give some more info. like the error code being displayed, then I may be able to help.
Mar 04, 2008 | Panasonic FP-7735 Black and White Copier
Sharp AR-M162 All-In-One Laser Printer Logo
434 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
