Question about Yamaha Televison & Video
Recently purchased a 2007 Yamaha FX HO Waverunner. Previous owner used the boat in the Pacific Ocean. Must have gone swimming with both remotes...the small 2 button remotes for the L-Mode and Security Lock. Any ideas on resurrecting the salty little guys? Both have evidence of moisture inside the unit next to the circuit board. Once dried will the dealer have to reset the remote codes?
  • 6 Answers
SOURCE: Reset the remote control?
I have the same amp. Try leaving the batteries our for a while like more than a day. Also if you can join a wire from each battery terminal to the others for a while. That will short out the remote and 0 it. This should cure your problem. I have had to redo the remote many times. Also while the remote is out press all the buttons in as many as your can for a while.
Posted on Sep 01, 2007
SOURCE: DMR-ES30V remote and DVD panel buttons not responding
I assume you have fixed this by now, but if not, call panasonic's help line (number is in your owner's manual). They will walk you through the complete reset process (maybe 5 minutes). you will have to re-program everything the same as you did when it first came out of the box, but that doesn't take too long. Also, first try taking the batteries out of the remote. Make sure they are still good. Wait 60 seconds or longer, then replace batteries.
Posted on Jan 03, 2008
SOURCE: Remotec Remote - lost instructions and need to reprogram
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing
POWER and TV. Stop when the TV turns off (after pressing POWER).
If the device does not have a Power key, you can substitute another
function, such as digits 0~ 9 , CH▲, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from its
library to the selected device, starting with the most popular code first.
5. To lock in the code, press and release SET.The LED will blink twice.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Posted on May 06, 2008
SOURCE: small universal remote control 'TOTAL control' brand
hi i have misplaced my universal remote control manual
the remote is a Total Control URC 11-4110
do you know the sequence for the seach i know that you hold the setup until the red light blinks twice but i forgot the rest
Posted on Jul 10, 2008
SOURCE: Search for your codes
Here is the owners manual in pdf. Hope this helps.
http://merchant.satisfusion.com/sf/library/manuals/owners/36udx10s.pdf
Posted on Aug 15, 2008
There is black mold (lots) in the undercarriage of my wave runner. How do I get rid if it - it's under the motor, very hard to get at ????
try using a mold destroyer agent ( bleach, mold remover , chlorine etc from a hardware /paint shop)
spray it in , let it sit for a few minutes then hose it out
repeat in a few days as mold spores will regrow
talk with a boat shop for other ideas
Sep 17, 2016 | Yamaha 2010 WaveRunner FX Cruiser HO
It Runs but has very little power,quits often,if you give it to much throttle it bogs down
Robert, First try new plugs, check fuel filter, sounds like it could be carburetor/injector issue, dirt,plugged jet, etc. Remove and clean/rebuild carb./injector.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
XLT1200 Bogs down
Thread 2004 FX HO ECU Problem
Waverunner Loses Power and Wont go Above 35 mph Solution
https://answers.yahoo.com/question/index?qid=20080525091900AATkgJh
May 23, 2016 | Yamaha 2004 WaveRunner Superjet Base
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
1989 yamaha waverunner. I purchased a 1989 25HP Yamaha Waverunner & was wondering how you check the engine oil?
Did you get any instructions from the previous owner? If it's a 4 stroke waverunner there will be a dipstick on the engine block, but I'm guessing it's probably a 2 stroke engine because most watercraft used 2 stroke motors clear through the 1990's. The oil will be mixed with the gasoline when you fill it, bottles of 2 stroke oil can be purchased at most stores that carry oil. Your waverunner can be mixed at 50:1, which equals out to be 2.6 oz of oil per gallon of gasoline. On a 2 stroke engine the engine gets lubrication from the oil mixed with fuel and will burn up fast if straight gasoline is used. Let me know if you have any troubles, but try to get ahold of the previous owner to get some more info.
Daniel
Aug 12, 2011 | Yamaha Superbike 1098 R Motorcycles
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Televison & Video Logo
231 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
