Question about Sony KP-57HW40 57" Rear Projection Television
What do you do when the picture isn't aligned and won't auto focus?
  • Sony Master
  • 8,617 Answers
Install the Repair kit called the Sony type 1 convergence repair kit from www.tvrepairworld.com the kit contains the parts and the CD with instructions.
Posted on Aug 03, 2010
My daughters 350d will only take pictures in manual focus mode, in auto focus it all seems good but it won't actually take the picture? Any ideas?
Shutter Assy, Mirror Assy or Shutter Button taken a coffee breaks.
You did try using a new battery?
Or your battery is not over 3 years old?
If I can help, just send me an email.
atdlee@netzero.com
Dec 30, 2012 | Canon Rebel XT / EOS 350D Digital Camera
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
I was trying to take pictures in a cave that had some light but not a lot. The flash will pop up and the light bursts, but it will not take a picture. It just keeps focusing in and out and it won't...
It's probably too dark and the flash isn't powerful enough to assist the focus mechanism on far away objects (more than 10-15 feet).
If you will need to switch to manual focus and maybe manual exposure.
Sep 08, 2011 | Canon EOS Rebel K2 35mm SLR Camera
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
My rebel t3 doesnt always take a picture when i press the button. It will focus and re focus but wont snap the shot
That means that there isn't enough contrast in order for the camera to get a subject in focus properly, if you can set back a little more that can help. The other option would be to have the camera focused where you want and switch to manual focus (which will leave the focus the auto focus found) and shoot the picture.
May 12, 2011 | Canon Cameras
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
The picture went fuzzy (color alignment).
craighirman,
try going to the antenna input from the menu screen, then trying to do the auto focus, or manual focus. My Samsung won't let me do the auto focus unless I'm looking at the antenna for some strang reason.
Oct 18, 2008 | Samsung PCL545R 54" Rear Projection...
Out of focus
Most times when the stk's are shorted the 5 amp cp fuse on the power supply opens. Check all of the cp's by the stk's and on the power supply.
Feb 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
