Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine is sending the F2 message. F2 says the drain in blocked or in someway impaired. After cleaning etc. it still says the same thing
  • 443 Answers
Did you clean out the pump filter/trap that is behind the bottom access panel that is across the front of the washer down below the door? (two screws at the very bottom, out towards each side, you can see them if you get down low looking at the front bottom area.)
GOOD LUCK !!
Posted on Aug 03, 2010
  • 5,081 Answers
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
* Check the drain hose and make sure it is not plugged or kinked
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
F2 fault
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair.
Jan 21, 2013 | Siemens Washing Machines
F2 error code flashes and machine wont finish the drain cycle
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
Our Front loading High Efficiency Washing Machine (Maytag) had a F2 code flashing and I can't locate the manual after I moved. Could you help diagnose the problem?
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display sud and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 02, 2011 | Maytag MAH8700A Front Load Washer
Machine doesn't drain water
The washing machine not draining water.This problem is related to few possibilities. 1) The drain pump is got loose to the drain hose. check the connection from drain hose to drain pump. 2) The drain is blocked by any thing.Like cloth or any thing like metallic nails or coils etc etc. 3) The drain hose is got blocked./The drain hose is not letting the water to enter the drain pump. In most of the cases the drain pump has to be removed and checked for any kind of blockages.This will clear the fault. ----------- Keep updated with any more queries.Thanks,.
Oct 14, 2010 | Washing Machines
My washing machine stops at around 28 minutes and displays F02. I keep unlocking the door and trying to reset it but it won't work. As well, it displays SIDS even when I use very little soap. We...
It is real easy, take off the bottom panel and open the drain pipe. A lot of water will come out and some other things clogging the pipe. Removed it and reassembled everything. Works like there never was a problem. Thanks to Kenmore for making the drain pipe easy to open
Sep 18, 2010 | Kenmore Elite 45986 Front Load Washer
My washer will not drain. I get what looks like an F2 error message I have followed the manual instructions to restart the machine ... hitting "second rinse" etc. Nothing. This machine is not old at all...
There should be three screws in the bottom panel of the washer. Remove the screws and the pull panel down and off. There should be a clean out drain on the pump - so,...you're gonna need a bucket. Hope this helps...(and good luck).
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Kenmore Frontloader Error message F2 will not drain
There is a hidden drain/coin trap underneath or in the back that is most likely blocked with socks or 3-in-1 laundry sheets by purex!
Fixed my problem and my sisters!
Oct 13, 2008 | Kenmore Washing Machines
Washing machine not draining, not occuring on every cycle. The "F2" code flashes during the cycle. "F2" indicates a drain problem. Is this the control panel or the motor that pumps out the water?
Possible your outlet filer is blocked, clean this out and refit. Refer to manual; the outlet filter requires periodic cleaning according to your usage; things shd be fine...
Aug 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
89 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
