Question about Yamaha YHT-370 System
Can i use my yamaha remote rav308 as a universal remote
Looking for a programmable universal remote control to work on my Yamaha a/v receiver # HTR 5450
DON'T buy a universal, buy an original or a facsimile remote for that particular model. They are between 40 and 50 bucks.
yamaha receiver htr 5450 replacement remote Google Search
Jul 03, 2018 | Yamaha Audio Players & Recorders
Code that support yamaha s661 on chunghop rm230e universal remote
Try using the code search function on your Chunghop universal remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different one. All universal remote controls do not contain all possible codes.
Feb 17, 2018 | Yamaha Televison & Video
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
How do i program a yamaha rav150 remote
You do not say whether your remote is universal but if it is, you can use code search to find codes for both devices. if a search through all codes stored in the remote is unsuccessful, you may have to try another universal remote. All universal remotes do not store all possible codes.
Jun 21, 2016 | Yamaha Remote Control RAV150 p/n:VZ338300
WHAT IS THE 5 DIGIT CODE FOR A HTR-6230 YAMAHA RECEIVER SOUND SYSTEM THAT I CAN USE ON A RCA UNIVERSAL REMOTE?
Did you check the manual? Did you contact the manufacturer of your universal remote for the code if they have it?
Sep 05, 2015 | RCA 4-Device Universal Remote
I have a Yamaha AX-V690 receiver but I do not have a remote control. Can I buy remote for this unit oris there a universal remote I can use? Thank you. Plz reply to: molly@prtc.net. Thks.
You can purchase a remote for it if you would like. The part number for that remote is: VS713700 You could also use a universal remote if you would like. But keep in mind that most of the inexpensive universal remotes only support the major functions such as Volume, Tune Channel, etc.
http://www.remoteyard.com/yamaha-vs71370-vs713700-rx-v90-rxv90-rxv900-rx-v900-en.html
This is a replacement, but this particular remote is pretty expensive, and you could probably get a nice universal for that price (the lowest I found it was $69.95). Good luck, hope I have helped!
Mar 03, 2011 | Yamaha RX-V690 Receiver
What is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Jul 25, 2009 | Yamaha RX-V563 Receiver
Code for Yamaha YAS 71 Surround Sound System
If you can get a new remote either buy a new one from Yamaha or do like I did (I still have my Yamaha remote) for 29.99 Radio Shack sells a Auvio Universal remote and all you have to do is use the "learn" function......operates all my stuff including my YAS-71!!! great remote!!!
Mar 25, 2009 | RCA RCR311B Remote Control
Yamaha remote to command Sony CD changer.
isn't that nice of them to just list the yamaha code for CD players? I sent yamaha an email about it. we'll see what they say...
have you checked out the new universal remotes that are out now?
http://universalremote.com/consumer/products.php
http://www.compuplus.com/i-Universal-Remote-Control-URC-R50-Digital-R50-Universal-Remote-Control-1028369~.html?sid=jn84494w6bxh2e2
Feb 26, 2009 | Yamaha RX-797 Receiver
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Yamaha YHT-370 System Logo
161 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
