Question about Dryers
We have a three prong cord on our kenmore dryer and our outlet is 4 prong. Is there and adapter for something like this?
    Scholar:
  • 32 Answers
You'll have to go purchase a 4-prong plug from your local hardware.
Once you have it, you will have to removed the old one and replace it with the new one. It's fairly simple.
On the back of the unit is a rectangular cover attached with a screw. Remove the screw and set plate aside.
Inside, you will see that there is a terminal with the 3-pronged cord attached. Us a socket or nut driver with a deep enough well to reach the tiny nuts on the terminal posts and remove all three nuts. DO NOT LOSE NUTS OR DROP THEM INSIDE.
Remove the old plug and discard.
Slide 4-prong cord through hole and position the 4 wires so you can get to them. The white wire will go on the middle terminal post. The red and blue wires will go on the outside terminals, doesn't matter which goes on which, just one on one outside post and the other on the other outside post. The final wire is green. This gets attached to the case of the dryer (the metal housing). Easiest way is to simply grab the rectangular cover and as you put the screw back in to secure the plate, make sure the screw goes through the green wire eyelet and is secure between the casing and the plate, thereby grounding the case.
The new 4-prong plugs and outlets are a new safety feature mandated by the government. It is meant to protect you from shock should any voltage hit the metal of the unit, it will ground through that green wire and not harm you.
If you have any further questions, feel free to contact me.
Best, G
Posted on Aug 03, 2010
I have a Kenmore Elite electric dryer model # 11063932102 that will not start. It was in storage for five months and it had some superficial mice issues on the body, which cleaned up nicely, but now it...
Did you replace just the plug end of the existing cord or the entire cord/plug cable at the dryer connection? You cannot just replace the plug end since the 4th connection is not made it won't work. The easiest solutiuon is to use a 3 to 4 prong adapter. See this video that explains it.
http://www.youtube.com/watch?v=ZBJhkyHSCmo
Nov 02, 2014 | Dryers
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Can I change the 220 plug on the stackable unit from a 4 prong back to a three prong.
Yes you can. Green in the middle and red and black to the matching sides coming in from above the block where your connecting the cord
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | Kenmore 98702 Stacked Washer/Dryer
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
I have a 4 prong power cord coming out of my Kenmore dryer and I have a 3 prong power outlet in my wall. Can I replace the 4 prong cord with a 3 prong cord, and if so, how?
Purchase a 3 prong cord at a home improvement center. and replace your 4 prong cord. all you need is a screwdriver.
May 02, 2008 | Dryers
I just purchased a new home and the pigtail of my Amana dryer is different than the electrical outlet and the dryer does not have a schematic to install a new 4 wire pigtail. Is there an adapter to change...
There are no adapters. But a dryer will accept a 3 prong or 4 prong cord. The extra green wire just needs to be connected to any screw on the dryer casing. Some newer dryers have a screw there for it..or u can just use the closest screw avalable......usually the screw for the cover works good.
Apr 20, 2008 | Dryers
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
56 people viewed this question
Top Dryers Experts
Marvin
Marvin
