Question about Keybowl orbiTouch (ABCDEFG-12345) (ABCDEFG12345) Keyboard
I am the beginning of the end. you can see once in a year but twice in a decade. What am i?
    Scholar:
  • 72 Answers
The letter E.
Posted on Aug 03, 2010
Please could you tell me the age of the Bernina 1020 and the 1020
Find the serial number, engraved into the metal on the back of the machine or low down on the hand wheel end.
First digit is the decade: 1=1970's, 2=1980's, 3=1990's
Second digit is the year in the decade.
E.g. my 1030 is 27230888 so it was made in 1987.
May 21, 2014 | Bernina Bernette 75
Have a mantowac 150 Model # BD0152A, plug it in and it begins the freeze cycle and will go thru the harvest cycle once or twice then it kicks off and everything melts. I can reset it and it will start the...
It is going off on a safety limit. Either taking too long to harvest, or too long to make ice. When you switch on, the pcb will flash once or twice. The manual , or usually a printed sheet inside the lid, will tell you which limit has been exceeded and what the likely causes are.
Sep 20, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
1997 front end shakes when braking
Brakes only require machining & such about every 3 years
I do take them apart once a year --to remove rust,inspect & lube,
as a perfectionist-- I say.
So you need a new brake guy
Answer is::: Very poor & sloppy-- who knows what has been
done to your brakes
Next was anything or I should say the complete front suspension,
drive axles,motor & transaxle mounts,struts,everything under there
every checked for worn parts.
I don't want to say you neglect things, but you need to be pro active
& really know what is done, when you ask for a service & pay for your
questionable services
Dec 01, 2012 | 1997 Mercury Sable
Is ir normal to replace rear brakes on a 2010 mercury milan with only 22,300 miles? 15-16,000 of the miles are highway miles
The rear brakes should last 70,000 miles, if
you disassemble,clean & lube once a year,
on the rear of most all cars
My question is --- have you not had years or decades
of experience with other vehicles?
If so, why would you ask that question?
Aug 25, 2011 | 2010 Mercury Milan
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Keybowl orbiTouch (ABCDEFG-12345) (ABCDEFG12345) Keyboard Logo
Top Keybowl Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Keybowl Computer and Internet Expert? Answer questions, earn points and help others
