Question about Casio FX-115ES Scientific Calculator
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the degree symbol. Then I type in 10 and hit the degree, minutes symbol button again - but I just get another degree symbol rather than a minutes symbol. Any help??
  • 4 Answers
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Posted on Aug 03, 2010
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
Jul 31, 2011 | Casio FX-115ES Scientific Calculator
How can i convert a decimal degrees on my casio fx-9860G AU PLUS to degrees,minutes,seconds
Use the ->DMS command in the [OPTN]-[ANGL] menu. Press the OPTN key, then select ANGL.
May 21, 2011 | Casio FX-115ES Scientific Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
How do i convert a degrees/minutes/second problem using the Casio Fx-115ES calculator? Can you provide an example? Thanks ZH
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
Sep 25, 2010 | Casio FX-115ES Scientific Calculator
Can I convert Degrees, Minutes, Seconds to Decimal Degrees on my casio fx-115 ES?
Press the SD key (just above DEL). You may have to press it twice if the first press produces a fraction.
Sep 19, 2010 | Casio FX-115ES Scientific Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Using my Casio FX-115ES
Use the key that is 3 keys below the ALPHA button. You must press that key, then place the number or equation you are trying to get the square root of.
Apr 13, 2009 | Casio FX-115ES Scientific Calculator
My casio fx-115ES is stuck in scientific notation
The FX-115ES can only handle ten digits. 14! is an eleven-digit number, thus the calculator can only display the first ten digits and a power of ten.
Feb 18, 2009 | Casio FX-115ES Scientific Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Casio fx-82ES scientific calculator
change the mode to stat and then start operating it in statistical mode
Feb 24, 2008 | Casio FX-300MS Calculator
Casio FX-115ES Scientific Calculator Logo
2,003 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
