Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
My bosch hammer drill 1199 vsr just stoped runing. what could that be? can you please answer? thanks.
  • 6,826 Answers
Sure, it could be bad brushes or a broken connection inside the drill.
Posted on Aug 03, 2010
My Bosch hammerdrill was working fine one minute and the next time I pulled the trigger.....nothing. It was'nt overheated. As I said it was doing just fine one minute and the next minute zero. It's about 5 years old and has gotten very little use.
Posted on Sep 13, 2010
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
My hammer drill got overheated
Hello. If the gun has cooled down and still will not start up then the gun will have to go into a Bosch service center for a repair. Here is the owner manual with the pertinent info
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00018v-1.pdf
please rate my answer as very helpful. thanks.. Joe
Apr 26, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
How do I replace the chuck on a bosch 1199vsr?
If there is a chuck bolt in the center (where the bit goes) remove it (left hand thread). The chuck is threaded onto the splindle(right hand thread). On some of those drills they have a small hole in the housing that lines up with a hole in the spindle. Put a pin punch in to lock the shaft so you can unthread the chuck. If you clamp a 3/8" allen wrench in the chuck it acts as a good handle. If there are no holes to lock the chuck, if you lay the drill on a bench and give the allen wrench a sharp blow with a rubber mallet it will unthread the chuck. If the chuck is damaged and will not hold an allen key you will have to cut the spindle off and replace the chuck and spindle.
Hope that helps
Jan 27, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Hammer drill quit
If it is an 1199, forget it. Replace the brushes and do NOT use for hammering. It is a design problem. My unit was repaired 4 times and hammered about 5 holes each time before same failure.
Jul 02, 2009 | Bosch 1617014127 Brush Set For 11224vsr
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Jun 26, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Just stoped working
make sure that in the speed selector you are fully on speed 1,2,or 3...sometimes you can fall inbetween and then it will do that...otherwise you may have overheated the drill and will need to deal with Grainger or another auth. Bosch dealer for warranty...if they don't fix you, buy a Hilti
Mar 02, 2009 | Bosch 13624 24V Cordless Hammer Drills
Hi Seadog--can I download a manual for a Bosch 1194 svr hammer drill on your website?
Go to the BoschTools website and look under service and parts. You can download drawings there.
Jan 31, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
716 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
