Computers & Internet Logo
Posted on Aug 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brand new laptop 2 days old it has flickered since opening box i figured maybe battery so ive charged it it still flickers and a pop up about moving heador somthing vibration and hard disk drive or somting
dpaulat
Level 2:
Scholar:
  • Expert 72 Answers
  • Posted on Aug 03, 2010
dpaulat
Expert
Level 2:
Scholar:
Answers
72
Questions
0
Helped
17889
Points
254
You should bring it back to the store and exchange it if it's brand new. Charging will not fix the issue, and it sounds like it has some hardware issues that need to be resolved by the manufacturer.
1helpful
Periodic battery light flickers on my 2003 town car.if you just tap on brake or flicker headlights .is there a separate diode that could cause this?
You have a defective alternator, that what is most likely causing the flickering light. A voltage output test will not reveal this.
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
1helpful
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
1helpful
Flickering battery light
The alternator is old and tired, having a hard time keeping up with the task of running all the elecrtricals AND charging the battery. If you put a voltmeter on it with the engine running, it would show the alternator's output at the low end of acceptable performance. Have it tested to be sure.
Yellow light flickers 4 times when trying to turn
If you don't get the flickering lights when you try to boot up with the AC adapter hooked up but no battery, it sounds like the problem is most likely a bad power adapter. Your battery is dead, and that's why you get the flickering lights, but the AC adapter is bad so you can't use it to power the laptop or charge the battery.
You can typically get a new adapter for $20 or so, or maybe even cheaper on eBay.
My mp3 player won't turn on.
may be its ur power key problem.
2answers
Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Problems sounds like a damaged power pin from pulling or jerking on the AC cable. I use a Cable Retention Device like the one in this video to keep from hurting the pin.
Grand Canyon Tech
Grand Canyon Tech
