Question about Garden
What is the proper belt configuration? - Garden
  • 760 Answers
You must have make and model numbers. A good source is:
www.searspartsdirect.com. If its a popular model besides craftsman it may be listed. After you see parts list look on right side for owners manuals.
Posted on Aug 03, 2010
1996 Ford contour automatic 2.0 L with air-conditioning and no turbo. How do I change the serpentine belt
Either locate the belt routing diagram that is usually located under the hood somewhere, or take a photo of the path of the current belt. Locate the belt tensioner pulley. Using an appropriate ratchet or belt removal tool, release tension on the old belt and slide the old belt off the pulleys. Thread the new belt over the pulleys in the same configuration as the diagram (or photo), release tension of the tensioner and slide the belt on it. Allow the tensioner to take up the belt slack. Inspect the belt for proper routing and to ensure that it is on all pulleys correctly.
Dec 10, 2015 | Ford Cars & Trucks
Need to know the configuration for installing a new belt on a Whirlpool AWA9708 7kg dryer
your model number doesn't show up but all whirlpool belts go on the same way,put the belt under the idler pulley and then onto the motor pulley,you have to push the pulley back towards the motor and then loop the belt onto the motor pulley and you want the ribs to be down touching the drum
http://www.youtube.com/watch?v=CFnXwmUb4f4
hope this helps and next time send the full model number off of the machine,just open the door to the dryer and look around the opening where you put the clothes in you'll see a tag with the full model number
Apr 09, 2013 | Dryers
Replacing drive belt
Yes, here are the steps,First take a picture of the engine. No matter how good your memory is, the moment you remove the drive-belt, you will by some unknown property of mental relativity forget the proper routing for the belt. Do not,--------------------------------------------------------------------------------
ELM 327 1.5V USB CAN-BUS Scanner
Mar 27, 2013 | Cars & Trucks
I'm trying to fix my dryer. The belt broke and broke the idler pully with it. I've got both replacments, but am having trouble keeping the belt from running out of the groove on the drum and...
This link here http://www.repairclinic.com/Dryer-Belt-Diagrams shows the proper configuration of how the belt fits onto the motor/idler pulleys perhaps this will help you to keep the belt on by checking thats its properly on the motor&idler pulleys. Just find your brand and veiw the diagram.
GENE
Sep 04, 2011 | Dryers
ALTERNATOR BELT SNAPPED OFF
the alternator is spun by the serpentine belt which also spins the steering pump and the A/C compressor. you need to buy a new belt and install it. the belts have different lengths depending on how the engine is configured. take your old belt to a parts store so they can measure it and sell you the proper belt. in order to put the new belt on you are going to have to pull off the service panel behind the right front wheel. so you are going to have to jack it up, put it on a stand and take off the right front wheel. it is nearly impossible to get the belt under the lower pulley without doing it through that service panel. when the belt is properly on all pulleys, except the tensioner, someone is going to have to pull and keep the tensioner back so the belt can be put into its proper position. there should be a small stick figure decal under the hood showing the tensioner and moving of it.
Jan 14, 2011 | 1999 Saturn SL
The belt fell off the dryer how does it go on
The belt usually comes off the rollers if you turn the drum by hand. The link below will show you the belt configuration for most Maytag models. Maytag machines are made in several configurations.
Dryer belt configurations
Sep 30, 2009 | Maytag Dryers
Replace belt on 2006 dodge 2500
need to find belt tensioner use wrench to take up slack from spring and use belt configuration in manual to replace belt properly
Aug 30, 2009 | 2006 Dodge Ram 2500
Serpentine belt diagram needed
i got a 1990 dodge daytona shelby with a 2.5 turbo there are 3 belts one is for the alt and water pump one is ps pump one is ac here is a link to some info and a diagram http://www.turbododge.com/forums/f4/f14/176277-alternator-belt-tensioner.html
hope this help keep that daytona runing it a good car o look on the hood there should be one on there
Jun 09, 2009 | 1990 Dodge Daytona
Two drive configurations
Direct-Drive Motors are linked directly to the blade and transfer all of the motor’s power to the blade. Belt-Drive Motors have a belt that transfers power from the motor to the blade. In belt drive systems, the motor can be offset away from sawdust generated during operation, causing the motor last longer. Belt drive systems require slightly more preventive maintenance than direct drive systems. So you'll need to check the belts for wear and proper tension periodically.
Aug 27, 2008 | Delta BC50 Left Handed Biesemeyer...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
