Screen flickers and then shuts off. The only way to get to come back on is to unplug it for a few minutes. Once it is plugged back in it can go 2 -3 days without happening again or it could happen again in 5 minutes.
  • 8,617 Answers
Try resoldering the vertical output IC
Posted on Apr 25, 2008
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My Samsung screen flickers on powering on until it stops after a few minutes. what can I do? Thank you all.
Unplug it and let it sit for a half hour and plug it back in, or call the company themselfs with the 1-800 # they give you.
Jan 02, 2013 | Computers & Internet
I bought new screen of ebay but it flickers
Did you check both ends of the LCD Screen cable? The end that goes behind the lcd screen at the top and also the other end that attaches on the board. Also put a piece of tap over where the connections meet on the lcd screen to keep it in place.
Did you reseat (unplug then plug back in) the 2 cables that are in the LCD Inverter located at the bottom of the LCD Screen?
Apr 02, 2012 | Samsung R519-53S Notebook
Flickering screen
Try an external monitor to the laptop and see if it flickers. If it does, more than likely your video card is going bad. If it does not flicker on the external monitor you probably have a loose video cable or lcd inverter cable. Go back inside and remove the 2 cables that go into the LCD Inverter that sits at the bottom of the LCD Screen, then plug them back in. Then unplug the video cable at the top behind the lcd screen, plug it back in and secure it with a piece of tape right where the two connections meet.
Mar 28, 2012 | ASUS U52F-BBL9 Laptop
My samsung refrigerator goes off everytime the electricity flickers, even for a flash or less than a second. It goes off and it does not comebacks on for as much as 24 hrs. Sansumg's technitions says...
The fridge can cut off if there is a power flickering or variation as the relay will be energised to trip off. Once the fridge is off the self timer - 5 minutes- will be active to allow the gas/oil to come back to the compressor as the flickering would have produced an irregular pumping.
After about 5 minutes the processor will energise the relay to contact and start.
Now the main issue is the voltage in your household. if the voltage is low then the fridge will not start again as it will click and shut off. So make sure that there is sufficient voltage in the mains supply. Also the plug point where the fridge is connected must deliver good voltage/current as the wiring must be good to carry the load . If not the fridge will trip off whenever there is a power flicker.
Finall if the power is good then the fridge mut be checked as it cannot be off for 24 hours. register you complaint for warranty service.
If power is irregular use an auto- voltage stabiliser .
Aug 09, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Screen blinks and then goes out. tap on side and causes flickers
sure sounds like loose solder joints, look for them in the deflection circuit, just find the hard plastic encapsulated body with the thick red wire sticking out of it thats where usually the loose solder joints develop.
Sep 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
TV turns on and then suddenly the screen will shut off but the power will remain on
there is a problem somewhere in the power supply or horizontal circut.
It will need a technition to troubleshoot this problem.
Thanks Guy9
May 04, 2008 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
