Question about Olympus ImageLink D-555 Zoom Digital Camera
My Olympus D-555 Zoom Imagelink camera will not power on.
My Olympus D-555 Zoom Imagelink camera has a blinking red light and will not power on. What does this code mean?
  • 65 Answers
SOURCE: The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised inside...new battery required i'm affraid!
Posted on Aug 07, 2009
BillB-SA
  • 2761 Answers
SOURCE: Olympus SP-560UZ "Zoom Error" then shuts down
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
richard191
  • 691 Answers
SOURCE: Hi Ive got an Olympus SP-550UZ digital Camera
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. "Zoom error" is repairable
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Feb 21, 2010
lock123
  • 6831 Answers
SOURCE: Zoom Error message on Olympus sp590uz
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
No disk need to reinstall d-555 olympus
Try the vendor's website:http://www.olympusamerica.com/cpg_section/cpg_downloads.asp?id=2
Mar 21, 2009 | Olympus D-555 Zoom Digital Camera
Olympus cartridge
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1183
Here is the link for the camera manual
As far as a manual for the printer itself you may want to call Olympus Technical Support and they can probably email you a manual. Their telephone number is 888-553-4448 option 5 and then option 1
Jan 14, 2009 | Olympus D-555 Zoom Digital Camera
Olympus D 555 Blurred action shots
Indoor actions in low-to-moderate light are very difficult. This is why professional photographers pay thousands for DSLRs with high quality high-ISO settings, and thousands more for big and heavy lenses that can shoot with a large aperture (small f-stop number) to get the most light into the lens and onto the sensor.
Your Olympus D-555 only goes to ISO 400, which is not suitable for indoor action shots, and the lens is f/3 to f/5 which is not a fast lens. What you are trying to do is simply not possible with this camera. You need good quality at ISO 1600 (or higher) and f/2.8 or faster for the lens. This will give you 8 to 16 times as much light gathering capability in low light situations, letting you use a much faster shutter to capture action shots in low light.
Dec 30, 2008 | Olympus ImageLink D-555 Zoom Digital...
FLASHING LIGHTS ON OLYMPUS IMAGELINK PRINTER
check for paper jam.. else repair
Sep 06, 2008 | Olympus Cameras
C-740 Ultra Zoom Olympus
the memory card will need to be formatted in camera menu to clear it up... this will delete all pics so be sure to download before formatting in the camera menu
Sep 02, 2008 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus D-555 Zoom Digital print driver Ilp-100
go to the olympus website and find software for the D-555 digital camera it will also have the printer driver for the ILP-100 http://www.olympusamerica.com/cpg_section/software_results.asp?id=1183&os=w
Jul 23, 2008 | Olympus D-555 Zoom Digital Camera
Printer paper and cartridge
Target carries the PH-40 and the PH-160 printer packs for the Imagelink printer. These are products that are made by Kodak as it is originally a Kodak printer.
Jun 21, 2008 | Olympus D-555 Zoom Digital Camera
Paper Jam Error when no paper jam
well it could be, but normally the material is always right, therefore it could happen to be really paper jamed that u canĀ“t see.
Sep 26, 2006 | Olympus D-555 Zoom Digital Camera
Olympus ImageLink D-555 Zoom Digital Camera Logo
44 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
