Question about GPS
How to connect wires to my narva 86460BL - GPS
Can you install a NARVA 68284 Heavy Duty Solid State Alternating Flasher Unit to a VF Commodore with CanBus?
I fail to see what the issue is or the correlation between a NARVA and a CanBus network protocol on a vehicle. Why do you ask?
May 06, 2018 | Cars & Trucks
Wiring diagram for trailer 2005 falcon wagon from car to trailer plug
Depends on plug type and number of Pins used.
Is it 5 pin or a 7 pin round plug or a rectangle plug ?
http://www.narva.com.au/products/browse/wiring-diagrams
Dec 24, 2016 | 2005 Ford Falcon
Wiring a trailer into a 2005 falcon wagon
Were do I find the Wiring Diagram from Galaxy Fulcher 2007 Caravan to Ford Ranger 2010
use a volt meter to work out which light is connected to which pin on Ford Ranger trailer plug . Hopefully it corresponds to standard trailer wiring diagrams. Test each wire could also use a light bulb with two wires soldered to it or a 12v dc probe.
http://www.amazon.com/6V-12V-24V-Motorcycle-Circuit-Voltage-Electroprobe/dp/B00GYVS0E2
http://www.ebay.com/sch/i.html?_ssc=1&_nkw=Voltage+Detector+Tester+Pen+Non-Contact+Probe+Pen&_sop=7
Dec 09, 2014 | Ford Cars & Trucks
How to wire in a narva 12v 30amp relay from the battary to ignition
LOOK AT THE CASE OR BOTTOM OF RELAY.....MARKED W/ ABBREVIATION TO ORIGIN
May 23, 2012 | Cars & Trucks
I have a 25 hp Mariner o/b with harness installed. I wish to connect to a Narva 64012 Marine 4 position key ignition switch. The color codes and where they attach to motor are: Red to + terminal at...
I will need to look at some diagrams and that switch. I am not familiar with that switch off hand and I need to look into the wiring diagram for that as well before I can give you a complete answer. I am not at home where I can dig into this at the moment but will be shortly. It almost sounds like one of the grounds is not correct but I need to be sure.
Thanks
Nov 11, 2011 | Boating
Please help western australia.britax trailer lights not connected properly.this is how currently connected.left hand trailer light top pin yellow,side pin green,bottom left pin brown,bottom right pin...
plug wiring is in
the following web site
ww.narva.com.au
the site is very specific for 7 pin , 6 pin and rectangular to round 7 pin
the small tag that you have to use to put the plugs together is identified at the top oh the round plugs
you can get the site by googling and typing in ---trailer plug wiring australia
Apr 02, 2017 | GPS
Aztek 2001 headlights going out.
Headlights commonly only last a 350-400 hours. If you're not getting this, you might have a power problem OR are using lower quality bulbs.
I like to use Narva Artic Blues - they have a higher output and last longer. Also, most auto stores will provide a free replacement if they blow very quickly.
Check the fuse for your headlights - if it is incorrect change it and replace it with the correct fuse. Other than this, you may like to check the wiring - check all the connections are secure and that there are no shorts in the cable.
Hope this helps, Sherwin
Dec 29, 2009 | 2005 Pontiac Aztek
Trying to install narva driving lamps unit has
In 12 volt DC automotive electrical systems black is always the ground wire or negative. Make sure you disconnect the battery before doing any electrical work (unhook the negative cable first). Don't splice into any wires under the dash, use a piggyback fuse connector on one of the accessory fuses eg; cigarette lighter.
Sep 20, 2009 | 2008 Toyota RAV4
GPS Logo
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
