Question about Refrigerators
My maytag sometimes has water coming out from beneth it somewhere and has a peculiar smell in the ref. and freezer part...i have taken all old food out but it still smells the water tasts fine but the ice has the smell and taste in it..
    President:
  • 3,773 Answers
Sounds like drain problem in freezer
Could be ice inside the drain too
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 03, 2010
I have a 3 yr old maytag ref/w/bottom drawer freezer. We have noticed water/ice under the freezer basket. Sometimes it is thawing and comes outonto the floor.Any ideas what causes this? I have not found...
Have you tried the following steps: 1) check that the gaskets are free of any damage, dirt, or ice. The door gaskets should seal perfectly on closing. 2) Or: turn off the ref, safely guard your frozen food, let the ref thaw totally and more. The purpose is to eliminate any undesired icing. If no succes and your problem gets worse call for help.
Feb 23, 2015 | Maytag Refrigerators
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES.
YUCKY BUT VERY REAL
Jan 05, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
We have water leaking in the fridge and it smells, we have to clean it every day. It is 6 years old. It is frost free.
There is a pan undert the bottom of your ref it has a plastic line apx 3/8 inch around that goes up to your freezer it goes up the back of the ref on the inside or inside the casing. It goes to a pan in the top freezer this line has pulled loose or become plugged try cleaning it out and pour a small amount of 10% bleach water in the freezer grill this is a air vent grill in the freezer it will kill the bacteria that usually has the smell of garlic. good luck
Aug 08, 2010 | Frigidaire Refrigerators
Have alful odor in freezer and ref,had some things spoiled and lefted bad odor in freeer and smell went into ref tooked everything out and washed them out good, and put backing soda in but smell was still...
empty the unit and put a dish of charcoal in the frig and the freezer. Let it run for a week and see if that helps. Some odors will get into the plastic and insulation and cannot be removed.
Eric
Nov 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Aug 09, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag Side By Side Problem
Check and make sure the drain pan under the refrigerator is in position and the drain hose is in the pan. If it misses the pan it will put water on the floor.
May 31, 2008 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
