Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
Not draining any water?
Nothing is clogged evrything works and pump spins and check valve is not stuck??? Anyone have any thoughts??? This thing is 2 years old,
  • KitchenAid Master
  • 43,501 Answers
Check your heating element..
DishwasherNot draining any water? - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 03, 2010
Water wont pump out code f-05
Clogged drain pump.
Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
If not, replace drainpump
Apr 14, 2014 | Hotpoint Washing Machines
Flashing but nothing happening
A-- If you hear the water filling for 3 minutes before the lights flash, 2 things could be happening:
a.1) water never reached the proper fill/run level so the computer prevents the heater from starting and alerts the user. There should be a code list in the troubleshooting section of the user manual describing the blinking lights and what they mean.
Solution- verify by sound if water flows at the same rate as the sink tap, if not then shut off the water and check the inside the connection hose for debris against the screen inside the hose end or insid ethe machine end where there is a intake valve. The debris keeps sediment out so it works but there's no auto cleaner for the screen.
a.2) Otherwise the heater itself is faulty meaning it does not conduct an electrical path or maybe overheating (could be dry) and the computer senses the wrong temperature either too high or too low.
Solution- A service call to determine the reason why; heater continuity, water valve, heater relay, hi-temp fuse, etc.
B-- Now, if you do NOT hear water filling for those first 3 minutes, 3 things could be happening;
b.1) House water supply is turned off.
b.2) hose is clogged (see solution a.1 above)
b.3) Drain pump inside dishwasher was clogged during the last run and old water didn't drain out (maybe some water is evident in the tub bottom).
Solution- Most dishwashers start each wash cycle with 30 second drain pump running to make sure the tub is completely emptied so the next fill cycle can't overfill. This ensures that if the user finds a 3 liter pot that flipped over during the last wash and if they dump that full pot of water into the unit to make it lighter, that the water will get drained before the new water enters the tub.
If the drain pump is clogged reset the power and restart the wash cycle. Note how much water is in the tub and see if it goes down any during those 30 seconds by opening the door afterwards. Find the clog either a bone or plastic bag or some small pice of a childs toy is stuck in the drain pump or the other end is clogged maybe by grease or bones if you have a sink disposal unit. The things they grind up drop into the drain 1" inch above the hole for the dishwasher drain tube.
NOTE: There is also an overfill [float] switch if the water inlet valve gets stuck open and the water keeps filling, the drain pump is switched on until someone comes and shuts off the water supply. When the tub drains the float drops and the drainpump stops. This will also make lights blink so check the user manual for codes or call the factory service reps [1-877-337-3639].
Either way, there should be instructions to reset the machine for restart. If it doesn't reset you need someone to fix the control that tripped the unit, maybe a safety fuse or a broken piece of the puzzle.
Aug 17, 2013 | Haier DW12-PFE2 24 in. Dishwasher
LG dishwasher will not drain
wow !! you sure seemed to be very through in your troubleshooting , but one thing I read that you did not see/test was the drain solenoid valve , this is a medium size valve just near the pump that opens to drain line from pumps discharge to allow the water to exit the machine , otherwise it just gets to go up and around the machine again , these especially on "used well" machines tend to rust up and stop moving , a new replacement and there off running again
Mar 02, 2017 | LG LDF7932ST Dishwasher
I have a MDB-3. It is not draining. when the cycle is over there is 2 inches of water in the bottom. Hose is not kinked... Nothing is stuck in the washer... garbage disposal is clear... any thoughts?
There are a couple of things to check. If you put in a new disposal make sure the drain hole knockout is out of the disposal. Check the sump pit of your dishwasher. You may have to disassemble some to get all the way to the drain pump. Check the drain pump. Is the drain pump running or is it just buzzing. There could either be something stopping or clogging the pump or the pump could be bad. Some d/w have one motor for the drain and circulation and have a solenoid turn on for the drain. Make sure the solenoid is working if this is the case. Please rate this post.
Dec 15, 2009 | Refrigerators
Kenmore washer fills during spin cycle and doesn't drain completely
HI, this is just a slight clog or faulty drain pump. check the following areas.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 18, 2009 | Kenmore Washing Machines
My whirpool washer won't drain
check the following areas to help troubleshoot this issue.
2. Water Pump
Jun 18, 2009 | Tecnik TKL9260 Front Load Washer
Washer will not drain says check for kinks in hose
Check the following to address this issue.
2. Water Pump
Jun 04, 2009 | GE Profile WPRE6100G Top Load Washer
No drain or spin cycle
Check the following to address the issue--
2. Water Pump
Jun 03, 2009 | Kenmore 22422 Top Load Washer
Does not complete spin cycle
Ok, when this happens, its usually because of a drainage issue. the spin cycle has to work in conjunction with the drain pump to remove the water during the spin cycle and, if there is a clog or drainage issue, the spin cycle will shutdown. check the following to address this drainage issue.
2. Water Pump
Jun 01, 2009 | Frigidaire Washing Machines
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
2. Water Pump
May 31, 2009 | Maytag Washing Machines
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
48 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
