Question about Dryers
Just like Jill875 Frig Gallery Heavy duty...would dry good for the longest time...not it BURNS up. The lint vent is clear and the drum turns
  • 10,319 Answers
The timer relay is not operating. Have it serviced before a fire erupts
Posted on Aug 03, 2010
My dryer is an Inglis, heavy duty 6 cycle, 4 temp, autocycle that is about 7 years old. Recently it just heats up but does not dry the clothes. They are steamy hot but wet. I checked the vent, it is not...
It sounds like the blower is not forcing air through the dryer. I would start by turning the dryer on and checking the vent exhaust to see if there is a good healthy air flow where it vents to the outside. If there is not good air flow, start back tracking the air flow for obstructions or other problems. Check the lint filter to be clean, check the air piping to be clear, check the blower to be clear and functioning.
Oct 03, 2013 | Dryers
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
I have a Sears/ Kenmore model 70 heavy Duty eletric dryer, this months eletric bill was almost twice what it normally is and we realized that it has been taking longer and longer to dry the clothes. Once...
Long drying times are ALWAYS cvaused by poor air-flow in a dryer.
The causes are many.
1. Go outside and check the thru the wall dryer duct flapper. Make sure it is free of lint.
2. Pull the lint filter and wash it with vinegar. The water then soap and water with a very good fresh water rinse.
3. Inspect the area where the lint filter is installed for any signs of lint build up. Use a crevice tool and a stretched out and folded in half wire coat hanger (Looped) to reach deep onto the lint build up areas so you can remove the lint with a crevice tool and Vacuum.
4. Remove the vent duct from the back of the dryer and check the air-flow. The air-flow should push a relaxed hand / wrist gently away from the dryer vent hole with the dryer on. If you do not get this kind of aor flow you will need to ensure all of the lint has been removed from the internal dryer ducting. If your sure the ducting is clear and you stil have poor air-flow then most likely the blower wheel has failed, Most of the time the center hub will crack and the blower wheel will not turn at full speed. Other times a fan blade breaks and blocks the ducting.
5. Use a flash light and look into the vent duct hole on the back of the dryer. Check for a restricted duct. Clean as necessary.
The above are the most common reasons for higher electric bills and long drying times.
Have a 2nd person look for lint after your done cleaning! The more eyes the better.
Thanks for choosing FixYa,
Kelly
Jan 25, 2011 | Kenmore Dryers
My whirlpool duet dryer is only 4 years old and it does not dry the clothes completely, even when it is on Heavy Duty. Only way it dries the clothes is if I run it through 2 cycles.
Check to see that the lint filter and exhaust duct are clear all the way to the outlet. If the moist hot air is not being exhausted the clothes will not dry. If the vent path is clear and you are using auto-dry the sensor may be at fault.
Aug 13, 2009 | Dryers
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Dryers
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Takes almost 4 hours/timed cycles to dry 1 load of bedding/sheets
most of the time your complaint is the home owners house venting.run a load with the venting detached[it wont hurt a thing] if ok then must clean venting till dried as well as with out venting.if still long dry times first must make sure air ways in dryer are clean[should have good air flow at back if hand held there] and may need to remove front to clean lint filter area.and inspect blower ,making sure mounted to shaft and not worn in the center[blower key way, inside the hole where motor shaft goes thru blower]you dryer only has one element so if you have heat its heating.if you did all above and have problem still can be electronic[thermostats,timers etc........but i have fixed 1000s of dryers and their having problems are rarer.i hope that helps God bless ,tom
Jan 08, 2009 | Maytag Dryers
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryers Logo
15 people viewed this question
Top Dryers Experts
Marvin
Marvin
