Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
When I push in my code on my keypad to gain access, the door won't open and the keypad blinks 5 times. I am out of town and I have pets that need to be fed. Please help
    President:
  • 3,197 Answers
Your keypad could have just quit working or the receiver in the motor unit could have failed. You will have to find another way into the house until you return home and try your car remote. Then you will know if it is the keypad or the receiver.
Posted on Aug 03, 2010
Why won't the keypad outside mount not open the garage door but the remotes work fine.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
Sep 02, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Door ajar light on and locks keep locking and unlocking
need to gain access to the BCM to see which door the module is seeing open. the locks won't lock with key in ignition and a door is "open"
Jun 09, 2012 | 1997 Chrysler Town & Country
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Wireless keypad won't accept our original code. Door won't open. When I enter the code the backlight on the keypad blinks rapidly. I need help. I have no other way to get in my...
Sounds like the receiver in your opener has quit working. Unless you break in you need to call a door technician. They can drill a hole in the door, use a special tool to pull the manual release and open the door. You should then have them install a keyed manual release if this ever happens again. They can also repair or replace your opener.
Jun 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster garage door keypad which when the code is entered now just blinks and doesn't raise the garage door
Change the battery in the keypad and reprogram
Program:
1- find learn button on back of motor
2. push the learn button ( LED stays on for 30 seconds)
3. during the 30 seconds enter a 4 digit code on the keypad , then press the enter button for 5 seconds
NOTE: do not pass throught your safety sensors when programming
Apr 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Blinking on learning indicator...push the remote or wall button nothing works...what happen?
If that LED is blinking a code let me know what it is. For instance 5 blinks and a pause then repeats. If it is just blinking randomly that is normal.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door keypad
The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
60 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
