I have one TV LCD VIZIO VX37L the problem when it turn on it ,only filament is on,no display menu ,input and no sound, need help, please.
  • 11,361 Answers
You need to check the main power supply voltages, check the DC filter caps, solder joints, etc, also need to check the backlight inverter board for short circuits. You can read my guide to see if you will really want to do the repair youself. Right now it can be the power supply or main logic board, start at the power supply module first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 03, 2010
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
I have a Vizio VX37L HDTV........just yesterday....the tv started showing "no signal" when turned on....and powered off within 5 to 10 seconds. Any ideas?
POWER BOARD MALFUCTION.
POSSIBLITY, A $300-$400 REPAIR.
OR, YOU MAY BE LUCKY AND IT IS FAULTY CAPACITORS.
PLEASE LET ME KNOW WHAT THE PROBLEM WAS.
Jun 06, 2011 | Vizio VX37L Television
Vizio VX37L LCD TV can not stay on for one minute. When I turn on the TV set, the power on for about 30 seconds, then automatic off. No picture, no sound at all. Please help.
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck....
May 23, 2010 | Vizio L32 32 in. LCD HDTV
I have a vizio vx37L that powered on for about 5 10 min then went to a black screen but I could still hear sound. When I unhook the Direct tv it has balck screen still and no sound screen flicks when you...
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is a long shape board.
Apr 21, 2010 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
Jan 02, 2010 | Vizio VX37L Television
White screen LCD with sound
Ur tv LCD inverter board it dead.Replaced it u get ur picture back.
Dec 05, 2009 | Vizio VX37L Television
VIZIO 52" LCD is on but....no display
If this is indeed an LCD and not a plasma, then you need to replace the LVDS (LCD controller) board.
May 18, 2009 | Vizio GV52LF 52 in. LCD TV
VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Nov 22, 2007 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
